3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Solar Powered Walkway
I sure loves me some sun jars!  They incorporate several of my favorite things to mess around with:  LEDs, Solar panels, hot glue, man it's all there and they look great to boot!
However, there is one big fat problem:  the sun!  When it's dark out, oftentimes the places I'd really like to have a little extra light are just the spots you can't leave a sun jar due to lack of direct exposure to sunlight.
The obvious solution to this dilemma is to separate the solar panel from the sun jar.  I extrapolated this a bit further and realized that the only thing you actually need in the jar is the LED, and since you don't have to cram all the other electronics in there, you don't have to stay with the classic sun jar shape.
With this in mind, I combed craigslist for some suitably shaped glass blocks, went to Home Depot for the appropriate solar light, stocked up on speaker wire and came up with the Solar Powered Walkway!
***UPDATE 5/5/10:  If you build this project yourself, or something similar, post some pictures and I'll send you a patch!***
****UPDATE 1-1-11
If you are the first person to post a picture of your completed light-up walkway to the comments, I've got a 3 month pro membership to instructables that's all yours!
Step 1The Walkway
The Walkway
Here is the little path that goes from my driveway to the front door.  I decided this was the best place to put the lights, mostly because I wouldn't have to move a bunch of concrete, but also because I'd get to walk the path each night when I came home from work.
I figured I'd put one of the glass blocks in the path first just to see how it would look during the day.  I dug a little hole, just a bit deeper than the end result would be.  I poured a little fine gravel into the bottom of the hole, so you wouldn't just be looking at dirt through the glass.  I filled it back in around the block, and left the top just a bit higher than the surrounding gravel, as I figured it would settle out a bit.  Everyone who saw it thought it looked nice, so it was off to the next step.
201 comments
1-40 of 201next »
May 15, 2012. 5:30 PM3tbones says:
love, love this project...I seen your updated comments about this project, informing that you would not recommend the dealextreme LEDs for this project (not bright enough), what would you now rcommend and where would you suggest I get some of them, cause I really want to make some of these this summer. If possible could you post a image of what I should be looking for when getting the LED lights Thanks for sharing this project, I really love them.
May 7, 2012. 11:46 AMlove2die100 says:
wow what an idea,thx4sharing.
Apr 12, 2012. 12:42 PMTabbytha says:
Hey, I'm 37 and I would probably hop the bricks too... and I wouldn't be on anything... just let people have their fun and enjoy life!! you've created something cool and not often seen so live it up and let others do the same, long as they don't break anything or hurt anyone :)
Keep building and being awesome!!!
Mar 2, 2012. 1:33 AMpaverlight says:
Nice to see the site it is really very awesome the sun jar is very good product of the solar lights if you want any more about the solar lights feel free to visit us at the solar paver lights
Oct 19, 2011. 6:53 PMsolarstudent says:
did you need to edit the battery holder to have all of the batteries in parallel? I find it common with LED projects that batteries are in parallel to help increase the brightness. Your LEDs look pretty bright tho, so if you left the battery holder as is I guess it works out pretty well too.
Oct 18, 2011. 6:55 PMsolarstudent says:
For the in-ground lights: isn't the circuitry on those limited to 1.2V usually (enough to charge the one battery it needs)? If so, could we just wire three of those in series to get the 3.6V we need? I'd prefer to not spend $25 for a solar light that has the circuitry to charge three lights if I am just going to be tearing it apart. Wouldn't mind spend like $6 on a few of those garden solar lights though.
Aug 16, 2011. 11:38 PMsurf_frog34 says:
Great project. I couldn't find if this was covered, but how long do the lights stay lit with that setup?
Aug 14, 2011. 8:51 AMlschwartz says:
Around the 4th of July in the US, many stores, e.g., Walmart, Home Deport, Lowes, sell single stick-in-the-ground lights, decorated for the holiday, for as low as $1 each. The ones I found have everything contained in the cap that just snaps off. Next year, I'll get some and disassemble them to use as you suggest! Thanks for sharing.
Jul 24, 2011. 2:59 PMshilicious says:
Right now I am living in an apartment complex, and am trying to find any excuse to make these! They are so whimsical looking, and the possibilities are almost limitless. Thank you for such a great instructable. I can't wait to make these. C:
Jun 18, 2011. 6:14 PMeamc317 says:
This is a great project and will try to make it soon! Do you know how much weight these can hold, like could these break if stepped on over a long period of time, or are they pretty sturdy. Thanks again!
Jun 24, 2011. 12:52 PMeamc317 says:
Cool, thanks! Will try to make them soon. Thanks again!
Jun 14, 2011. 2:10 AMporcupinemamma says:
Briliant. awe- "sun" . way to go!
Dec 29, 2010. 3:19 PMGalonii says:
do you think you could set the glass blocks in concrete I was thinking of doing my drive way in Feb. and think this would be really cool.
Jan 10, 2011. 12:59 PMDetoxinatorSmith says:
My Dad and I put some blocks (without LEDs unfortunately) in his backyard patio about 10 years ago, we ended up using 3/4" cedar boards to make a form to set the blocks in so they were not sealed in place by the concrete, nice thing about cedar is you dont have to take them out, we left ours in and they give the blocks a nice little 'picture frame' look to this day.
Jun 14, 2011. 2:08 AMporcupinemamma says:
Pictures? Sounds so hot!! (sun/hot) tee hee hee
May 20, 2011. 8:22 AMmrdudej says:
Do you think this would survive a canadian winter?
Apr 11, 2011. 12:29 PMDr. Newell says:
I just found this instructable and I'm considering a version for my ongoing backyard remodel. I plan to pour two concrete walkways in the upcoming weeks, and thought about incorporating about 20 of these lighted blocks into the surface. Here's my plan:
1. Power everything from a 12 volt automotive battery in my shop, charged with a 18. 8v, 170 mA solar panel from a Volswagen New Beetle battery charger placed on the roof of the shop.
2. When I form up the walks, I plan to build forms for each block and connect them all with pvc conduit for the wiring. Add a little slack to the wiring and I should be able to make all my connections, then drop the blocks into place. This system should allow me to remove blocks as needed for maintenance, and the conduit will let me run additional cabling to the blocks later if I decide to get really crazy.
Apr 3, 2011. 2:22 PMmrtsunami92 says:
where do i get thoose glass blocks ?
from ebay?
can anyone send me a link please ;)
greets
Mar 2, 2011. 7:46 PMmoogeez91 says:
hey the link candor posted isn't working. is this product gone too?
Dec 20, 2010. 9:52 PMfrikkie says:
very very beautifull!
Dec 6, 2010. 10:34 AMCaribsailor says:
Very Cool!! Great Job!
I've done something similar disassembling a solar landscape set & conch shells.
But I'm going to us this one for sure at the canal lot. Love it!
Cheers
Caribsailor
Mar 18, 2010. 10:30 AMquilt45 says:
Wow!  These are super cool!  I love the look of your pathway.   I think that this would look fabulous around a pool if there was a way to get them non slippery.  Would the etching that someone suggested be textured enough do you think?
But what did you do with the bundle of wires at the end?
Don't they have to go up to the charging station, and wouldn't that leave them just sort of hanging there?  I get the burying them underground as you go closer to the charger, but you said that you had mounted yours on the roof.  Did you just feed them through a PVC pipe that is the color of your house?
Nov 21, 2010. 9:25 AMDIYDragon says:
If you do want clear griptape. Try look looking for the kind that is for skateboards. Should be very easy to apply and locate. : )
Great project.
Sep 23, 2010. 7:27 AMshtihl says:
what about using clear epoxy with grip sand? you know, the kind of sand you usually mix with latex paint to make a non-slip area for use on decks and steps and ramps?
1-40 of 201next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
306
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
