Step 3Get to work!
Within the body of the light, unsolder the LEDs and replace them with about 6-10 inches of speaker wire. Make sure to seal everything up well with epoxy or silicone! Mount this whole assembly on your house first, make sure it works, then prepare your glass blocks. I used epoxy (because I'm an idiot) to mount the panel to the roof and the body under the paper box, and then stapled the wires in place.
At the corner of each of your blocks, mount an LED of your chosen color, tack it in place with hot glue, then cover the whole shebang in epoxy or silicone. Make sure you leave the leads exposed!
If you do make something like this, please post some pictures, no one has yet! If you do, I'll not only send you a digital patch, I'll send a 3 month pro membership your way!
Thanks for commenting and I'm glad you liked it! If you do make some, post a picture and I'll send you a patch!
If you look at the links in step 2, I've got some solar christmas lights there. In fact, I just got a package of them in the mail that I'm going to use to build a walkway like this under my brother's grape arbor.
Also, if you do build this, post some pictures and I'll send you a DIY patch!
I think mounting the light in the side of the brick is better, because the light will propagate through the block better than if it's just pointing straight up.
Thanks for the comment jmcarlin!
I found these lights hanging from a display rack right next to the other solar outdoor lights. It was a while ago, so hopefully they've still got them!
Thanks for the comment!
thanks.
I just used 5mm superbright LED's I picked up from dealextreme.com, they're about 10 cents each.
