How to Make a Stove for $1
7,225
22
7
Posted in OutsideSurvival
Introduction: How to Make a Stove for $1
About: Visit my Youtube page at http://youtube.com/user/camdog7d
Things you will need:
-$1 metal water bottle
-hack saw
-metal drill bit and drill
-sharpie
-heet or 90% alcohol
-jb weld or aluminum tape
-sandpaper(optional)
This is a metal stove and it onle take about 20 minutes to make. It is great for backpacking, camping, survival, and anyday use. I made mine and it works great for boiling water for hot cocoa. I will add a video of it in action soon.
Step 1: Use the Sharpie and Mark the Cuts
Now you have to draw line on the botttom and top of the bottle like in the picture below. Also remember to have them both be the same height.
Step 2: Cut the Marks and You Are Finished
Cut the bottle on the lines that you have just marked. Cut the marks on the lip of the bottle in half a centimeter. Next if you want you can sandpaper all of the color offof it to make it look much better. Lastly all you need to do is use jb weld or any other kind of thing to combine it ( i heard that aluminum tape works okay) and then fill it with an ounce of heet or any other type of lighter fluid, light it, and be safe and have fun!
    • Outdoor Fitness Challenge
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    7 Comments
    Does the flame come out the sides or in the middle? A pic of this with flames might be good to show. I hope you don't have it lit with the plastic lid inside like you have in the last pic.
    No the flame come out both the hole on the side and the middle of it but if you put a pot on top of it the flames will come out the side holes to heat the pot and thepicture of the plastic case inside is how I bring it with me for camping or backpacking.
    Thanks for sharing this. I just made one like this but I have a problem that when I place the pot on the stove, the flame start to go down till it shut down completely. Do you have any idea what may cause this?
    Sounds like your cutting off the air to the flame. You need to have a little space under the pot for the flame to get enough air.
    I would assume the last pic is of the stove packed and ready for hiking. Also, I'm assuming this is a simplified version of the "Aluminum Bottle Alcohol Stove." Camdog7d, am I correct in these assumptions?
    Yes you are correct thank you for making comparisons because it gave me more ideas for my stove.
    90% rubbing alcohol is cheaper than heat and burns alot cleaner.
