How to Make a Strobe Light at Home
154
Posted in TechnologyGadgets
Introduction: How to Make a Strobe Light at Home
About: Hello friends i show how to make stuff with no skills easy to replicate step by step from powerbanks,generator,invertors and so on thanks
How to build a strobe light for your party or if you want a strobe illusion a flashing light is now very easy to make.
For this project, you will need lights bulbs any will work and a very important part is a neon starter you can find them in DIY shops. For making a led strobe light just take normal led bulbs and test then you can try colored bulbs and just connect the bulb and the neon starter in series and you are set now enjoy. The stroboscope is now ready for your optical strobe illusion.
The music used in the video is downloaded from the website www.bensound.com and are rated at royalty free music dubstep -www.bensound.com dance- www.bensound.com funky element - www.bensdound.com
If you find this video useful like share and subscribe https://www.youtube.com/channel/UCPjqH3HfNA4Shttkx1haAUQ Thanks for watching and see you next time all the best! Others electronic projects with NO Skills Required: Washing machine motor generator https://www.youtube.com/watch?v=_jKTsAJK8aQ Washing machine motor wiring basics https://www.youtube.com/watch?v=XlaHSZFGzp0 Washing machine motor speed control https://www.youtube.com/watch?v=lRj6V7ygBQo Incredible washing machine motor on battery https://www.youtube.com/watch?v=TcMUTqSvOsw
Step 1: Warning 220v Danger
be very careful when operating under mains voltage one mistake and that's it so disconnect the wires
before you start experimenting be safe than sorry.
Step 2: Parts for the Stroboskop
You will just need a gu10 connector that you can find in DIY shops or electrical equipment stores
and a neon starter 1-2 £ so you just have to connect them in series with the main voltage
and in the gu10 connector, you can experiment with multiple bulbs.
In the video, i try a 50w incandescent one a 3.5w led, and another 0.75w led
i did find out that the incandescent works best but you can try more bulbs even colored ones.
Step 3: The Diagram and Bulbs
A strobe light or stroboscopic lamp, commonly called a strobe, is a device used to produce regular flashes of light. It is one of a number of devices that can be used as a stroboscope. The word originated from the Greek strobos, meaning "act of whirling."
A typical commercial strobe light has a flash energy in the region of 10 to 150 joules, and discharge times as short as a few milliseconds, often resulting in a flash power of several kilowatts. Larger strobe lights can be used in “continuous” mode, producing extremely intense illumination.
The light source is commonly a xenon flash lamp, or flash tube, which has a complex spectrum and a color temperature of approximately 5,600 kelvins. To obtain colored light, colored gels may be used.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
