!How to Make A CD Rack!
 by Alex Jalland
Featured
Step 8: Product in its environment
From these pictures of the final product you can see it is fulfilling its main function as a CD rack. From the trials users have said it looks like a designer product. I have assembled it in a number of ways, but these are not the only layouts. The material I have used is oak wood, it is a hard wood so it can withstand the occasional bump. Fully assembled the unit is 1500mm x 1350mm. The rack can hold over 300 CD’s. This is well over the expected  capacity and is a great result.
Each piece has a number of slots and some pieces have the slots on the top and others have slots on the bottom, the pieces can be put together in a number of ways. Different options have been illustrated above. Some ways may look better than others so it is probably best to see what they look like on the floor before you drill it to a wall! The  speakers are slightly less interchangeable  as they are restricted by wiring but the length between each speaker is half a metre, this means that a speaker could just go in each corner of the full structure.
Alex Loftie says: May 18, 2012. 11:26 AM
I took that photo!!! =)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
