Materials:
standard bridal petticoat
Rit dye
rubber gloves
old towel
newspaper
large pot
salt
detergent
stirrer
scissors
pins
sewing machine
Remove these ads by
Signing UpStep 1Dying the Skirt
Fill up your pot with hot water, add the packages of dye, a scoop of detergent, some salt, and stir very well. Then heat it up on the stove.
Get the garment completely soaked with water.
Since the item we're dying is pretty large, we're gonna use a big plastic tub to do the actual dying process in. Otherwise, we would do it right in the pot where we did the dye bath. Put your garment in the dye bath and completely submerge it. You wanna leave it in for about a half an hour and the whole time you should be moving it around because it needs constant agitation.
Once you've reached your desired color, take it out and thoroughly rinse with cold water.
Then hang it up to dry.
11
comments
Add Comment
canida
says:
Add Comment
