Step 1Ideas & Materials
My lines of reflections
I wanted to create an object which would blend with an apartment's interior along with the furnitures during the day and reveal it's mysterious aspect in the dark.
I have avoided using big and complexe tools so that it could be possible for anybody to make this lamp.
I have started to create my luminous patterns with Adobe Illustrator , after several 3D light simulations with Carrara, I have determined, according to me, the best harmony between light and darkness. My conclusion :
The lamp must not be overcharged with too many luminous lines because the visual effect will get degraded, on the contrairy if there are not enough lines, we simply lose the primary utility of the lamp ; to enlighten.
I have choosen to use Opaline Plexiglas ( also called Frosted Plexiglas ) for it's classy aspect and also because of it's light diffusion properties.
In order to liven the lamp up, I have used a color changing led light bulb.
The trick I found for having the maximum light through the lines of the pattern while having areas remaining completely dark was to use a mirrored paper to cut the pattern.
You will find the list of the materials needed, and all the instructions about how to make this lamp, in the following video.
Adhesive Vinyl Chrome Mirror ;)
e.g : www.edecals.com/Merchant2/merchant.mvc
