Step 2The Cube
Go to a specialized shop where you would be able to find already cut Plexiglas sheets ( or, if the shop assistant is cool, he will do the cutting for free )
Let us make this cube.
Remove the protective film from the plexiglas sheets.
Refer to picture number one for the gluing order. Use a thick book as a bevel to help you to glue the different sheets ( stick a piece of adhesive tape on the edge of the book to prevent it to open during the operation )
Once the cube has been made, heat a nail on an electric hot plate ( avoid using a flame because the black residue will stain the plexiglas )
Then, with the help of pliers, do a notch about the size of your powercord.
comments
Add Comment
Add Comment
