3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a TRON Style Lamp: The MADYLIGHT
Step 3The Cutting Phase
The Cutting Phase
Open the ZIP file and print the ' AandB.jpg ' file twice, the ' CandD.jpg ' file twice and te ' E.jpg ' once.
Cut the patterns, leaving a security margin of at least 1 cm, then stick them on the mirrored paper.
Use the X-acto knife and the french curves to cut the curved lines, then the utility knife to cut the straight lines.
After having cut one part, place a piece of adhesive tape on each side in order to maintain them in place. At the end, cut the squared shape ( be careful about the four corners which will be detached).
7 comments
Jun 10, 2010. 11:00 AMGes says:
Is there are reason you put cut out the design, and put them in the cube after it is assembled? I don't know how sticky the reflective material is, but I thought it would be easier to put the the designs on the plexiglass before you glue it together, just so you don't need to manoeuvre it as much in a cube.
Apr 1, 2008. 5:16 AMRadskull says:
HI, thanks for the great submission. I'm really looking forward to getting my lamp started but when i print the patterns (using windows picture viewer) they seem to big, what program should be used? or am i doing something wrong?
Jun 10, 2010. 9:54 AMBad Maxx says:
I can try to help, first of all did you actually print them or did they just look large in Windows Picture Viewer? If you printed them and still think they are too large then: The pictures are .jpg files, easily manipulated in size, if you are using Windows Picture Viewer you almost certainly have have a program called Paint. Paint in case you are not aware can be found under Start/Accessories/Paint or easier still, Right click on the picture, it should give the option to Open With: choose Paint. In Paint, choose Image then Stretch/Skew change the 100% to a smaller number, print the smaller picture, repeat until it is the size you want and then change the other pictures to match. Hope this helps..
Jun 21, 2009. 3:03 AMTubehacker01 says:
How the hell did you manage to produce such top-clas cartoon drawings???? Tell me, wich program and effects did you use?? GREAT INSTRUCTIBLE!!! 5+
Mar 31, 2010. 9:32 AMTheSaltyPilgrim says:
I know it's a little late but I just found this 'ible and thought I should chime in. You can get this same effect by taking a real picture uploading or scanning it into your computer and using photoshop to get the effect. I've seen it many times over.
Mar 31, 2010. 1:57 PMTubehacker01 says:
Okay, do you know the name of the effect? =D
Apr 21, 2009. 3:09 AMundinstructable says:
Hi. Congrats for your instructable I really liked it.... I also liked the style you printed the above picture (to be cotinued).... What effect did you use to achieve this cartoon-like style? It's amazing! Cheers!
Nov 13, 2008. 1:29 PMMr. Thumbs says:
All set to build the light, but I can't open your patterns. My computer says it does not recognize "smart pix". Is it my machine or the format you use?
Mar 10, 2008. 8:45 PMfreshnessninja says:
did you draw the patterns yourself or did you find them on the net somewhere. i wanted to make a UV reactive shirt in these patterns. inspiration via you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
71
Author:Greg Madison
I am a french illusionist magician, this passion choosed me when I was six ( yep ! I'm 30 and already 24 years of magic behind me). My major motivation : fully understand the mecanism of human percept...
more »
