Remove these ads by
Signing UpStep 1Materials
• 1' long 4" diameter PVC tube
• 5" long section of 1/2" CPVC pipe
• 1 airplane blanket (or other static material like rubber of fleece)
• Metal Bowls
• Scraps of 2x4
• Motor
• Dowel (lots of dowel)
• JB Weld (I now love this stuff)
• Hot Glue
• *Optional* a ball bearing for shoving in a hole
Also, 2 friends insane enough to do this with you!
don't you mean or ?
Would some old grey plastic guttering do as the pole that holds it up i think it is PVC or possibly U-PVC
http://www.sears.com/shc/s/p_10153_12605_SPM678183501P?sid=IDx20101019x00001a&ci_src=14110944&ci_sku=SPM678183501
*Do you have to wrap the rollers with conductive or non conductive material
*How many RPM is the motor
*Do you attach 2 metal combs to the top and bottom of the airplane blanket
*Do the metal comps touch the airplane blanket
*Does it matter which side of the airplane blanket is attached to the combs
*If you make it 3 1/2 ft tall, will it be safe to touch it still
*Do the combs attach directly to the discharge in the inside
*I think I saw the motor attached to an outlet, do you keep the current at AC, or do attach a regulator to it
* and, does the top roller move, or stay still
I am sorry for all the questions. The Instructable is great though!
• Non-Conductive
• Mine is 3450, the faster the better, but keep in mind that it needs to have some tourque
• They don't attach, they just almost touch it
• See previous answer...
• It'll just hurt like all hell (really? i want pics!!!)
• Attaching them to the outside is easier, but inside is better looking, and yes
• The motor is really a small part, many would work. I chose an AC motor because it was the easiest
• It can move if you want (or put a tube around a tube and make less friction), we just chose to keep it static
I don't mind at all, I'm more than happy to answer any question if you are nice.
Can you do the dancing monks trick?
They all get charged, until the person at the other end of the line touches "ground", at which time they all get a shock.
It was first done to a line of monks that was connected to ground, and then the first monk touched the ground of a charged Leyden jar.
- lighting a bunsen burner (or similar)
- making someones hair stand on end
- dropping feathers, then having them stick to the charged dome, then becoming attracted to the nearest neutral object (similar to how a balloon sticks to a wall after being rubbed on something)
- shocking someone just for fun
- producing mini lightning
