-Use Simple tools (needs only a drill press, band saw, and hand tools)
-Low Cost (this kind of got away from me however with everything bought off the shelf the cost for all parts is under $600 (significant savings could be made by skillfully sourcing some pieces))
-Small footprint (30" x 25" footprint)
-Usable working envelope (10" X-axis, 14" Y-Axis, 4" Z-Axis)
-Relativly fast cut rate (60" per minute)
-Small part count (fewer than 30 unique parts)
-Easy to source parts (all parts available from 4 sources (Home Depot + 3 online sources)
-Ability to cut ply-wood (Succesful)
Lets get started...
UPDATE: - Coming soon the ability to order pre-cut MDF pieces from oomlout
Step 1: Others Who Have Finished
Photo 1 - Chris and his friend put together this unit; laser cutting the parts out of half inch acrylic. Not only does it look super it must weigh a ton. But kudos, anyone who's worked with acrylic knows laser cutting it is great but it is a very very unfriendly material to drill and there is a lot of side drilling in this design. Good job guys, check out more details (and photos including some testing with circuit boards) on Chris's blog rainbowlazer.com. I particularly like his work with making 3-d objects out of 2d cuts (here) .
Photo 2 - Sam McCaskill has finished his desktop CNC machine and it's looking really really nice. Super impressively he also resisted the urge to cheat and cut all his pieces by hand. I'm really impressed.
Photo 3 - Angry Monk's - With MDF pieces cut on a laser cutter and drive converted from toothed belts to threaded rod
Photo 4 - Bret Golab's - Bret has completed his and gone through the extra step of getting it setup to work with Linux CNC (a task I attempted and was foiled by complexity). If you're interested in his settings you can send him a message (Instructable ID: bretlyssii ) ). Great job Bret!
(If you have built one and would like it featured here, please send me a PM and we can arrange for the sending of photos)
Step 2: Specs.
CNCZone.com - A discussion forum which has a DIY machine section which is a wealth of knowledge ( direct link )
Machine Details:
Cutting Head: Dremel or Dremel Type Tool
Axis Details:
X Axis
travel: 14"
Drive: Toothed Timing Belt
Speed: 60" min
Acceleration: 1" per second2
Resolution: 1/2000"
Pulses Per inch: 2001
Y Axis
Travel: 10"
Speed: 60" min
Resolution: 1/2000"
Z Axis (up down)
Travel: 4"
Drive: Threaded Rod
Acceleration: .2" per second2
Speed: 12" min
Resolution: 1/8000"
Pulses Per Inch: 8000
Step 3: Required Tools
Power Tools:
-Band Saw or Scroll Saw
-Drill Press (drill bits 1/4", 5/16", 7/16", 5/8", 7/8", 8mm also Q (5/16" closest imperial drill bit)
-Printer (seemed like the right category)
-Dremel or Similar Tool (to attach to the finished machine)
Hand Tools:
-Rubber Mallet (to provide "persuasion" when neccesary)
-Hex Keys (5/64", 1/16")
-Screw Driver
-Glue Stick (UHU) or spray adhesive
-Adjustable Wrench (or 7/16" socket and ratchet)
Step 4: Required Parts
Sheet Stock --- $20
-a 48" x 48" piece of 1/2" thick MDF (any 1/2" sheet stock can be used I have plans to make my next version out of UHMW but cost was prohibitive this time around)
-a 5"x5" piece of 3/4" thick MDF (this is used to make spacers so any piece of 3/4" stock found around the shop could be used)
Motors and Controllers ---- $255
-An entire instructable could be written on chosing a controller and motors. In short what is required is a controller capable of three axes of control (with pulsed step and direction inputs) and motors with about 100 oz/in holding torque. I sourced mine from http://hobbycnc.com they have worked well and the kit was quite easy to solder. ( direct link )
Hardware--- $275
-These parts can be acquired from three places. The conventional items can be acquired at Home Depot, the specialty drive products are easy to find at any industrial supplier, I used McMaster Carr (http://www.mcmaster.com) (I chose them because they have a nice online store), and finally because of the large number of bearings required I found the best price from an online seller (http://vxb.com) which sells 100 for $40 (leaves quite a few left over for other projects) ( direct link )
Software --- (free)
-What is required is a program to draw your designs (I use CorelDraw), and a programme capable of interpreting these files into pulses to be sent to your controller. I'm currently using a trial version of Mach3 ( http://www.machsupport.com )but have plans to convert to LinuxCNC (An open source machine controller which uses linux) ( http://www.linuxcnc.org )
Router Head--- (extra)
-I attached a dremel type cutting tool to my machine however if you are more interested in additive construction (like fab@home or RepRap) you may wish to look into their deposition tools.
Details
-the metric components and especially the cross nuts aren't very popular and I had to visit several Home Depots in my area before I had enough.
-I couldn't find a way to link to parts directly on the MCMaster Carr site. To find them go to www.mcmaster.com and search for the part #
Step 5: Printing Pattern
File Name and Material:
Summary: CNC-Cut-Summary.pdf
0.5" MDF (35 8.5"x11" tiled pages): CNC-0.5MDF-CutLayout-(Rev3).pdf
0.75" MDF: CNC-0.75MDF-CutLayout-(Rev2).pdf
0.75" Aluminum Tube: CNC-0.75Alum-CutLayout-(Rev3).pdf
0.5" MDF (1 48"x48" page): CNC-(One 48x48 Page) 05-MDF-CutPattern.pdf
(note: I've added a DXF version of the 0.5" MDF pattern to this step (DXF-05-MDF-SimpleDXF.dxf) I have removed the cross drilled holes and writing from this file to make it a manageable size, if anyone would like any of the drawings in a different format or including different information please just drop me a line and I'll do what I can)
(note: I've included the original CorelDraw format drawings in a zip file (CNC-CorelDrawFormat-CutPatterns(Rev2).zip) for anyone who wishes to do some editing)
(UPDATE: There is now a choice in patterns for the 0.5" MDF layer, you can download one file (CNC-0.5MDF-CutLayout-(Rev3).pdf ) with 35 8.5"x11" pages tiled, or you can download one file (CNC-(One 48x48 Page) 05-MDF-CutPattern.pdf) which has the entire layout on one 48"x48" page to print on a large format printer or tile yourself)
(Step by step)
1.Download the three layout pdf files
2.Open each in Adobe Reader
3.Goto the Print Dialog
4.(IMPORTANT) in the page scaling dialog select "none"
5.Check to make sure the file didn't accidentally get scaled to do this measure the printed ruler on page one of each pattern (make sure it matches up with a ruler you trust) (I didn't do this the first time and accidentally printed out a copy at 90% size more on this later)
DXF-05-MDF-SimpleDXF.dxf988 KBStep 6: Gluing Down the Pattern
1.Glue the tiled pages to your sheet stock (MDF) ensuring the edges match up
2.For the aluminum tube the pattern must be glued to two sides. If the Tube is laying flat on a table and you glue the side A patterns to the top side B can be glued on either of the side faces.
Tips:
-Use lots of glue
-Have something near by to help push down each piece
-Patience
(if anyone else has tips on doing this I would love to hear them)
Step 8: Cheating
Step 9: Hole Drilling
The areas with holes drilled overlapping are an attempt to create grooves if you have a table router that would work much better for this.
Visit Our Store »
Go Pro Today »
modifying the X and Y axes for threaded rod control isn't that bad, the only hard parts were making the new motor mounts and controlling both sides of the Y axis with one stepper. i ended up controlling both the Y axis threaded rods (one on each side) by mounting the timing belt pulleys on the ends of the threaded rod and running a timing belt around the rods on the back of the machine.
the reason for all this is because i want to do very small precise machining. i already have milled a couple propeller molds, to lay carbon fiber over, that are 1" in diameter and need 6000 lines of G-code to mill. i actually have another being milled right now. they came over very nicely.
i have a video of my machine in action but its hard to see any details of the prop because of its size and because my camera won't auto focus during a video. http://www.youtube.com/watch?v=_rdFn6b7b6o
I'm building one right now. The purpose of the machine is to mill PCB's i need the machine accurate to 0,001 . Did you try the machine with the standard building? How accurate it worked? Can you put images of the changes you have done?
just an FYI, i could run this CNC router at 30-40 ipm but that was only rapid traverse. when cutting i went much slower. and even on 30-40ipm you can miss steps, 12ipm is better, but i would only go up to 20.
http://www.gtghydroponics.com/store/0-0-715.htm
http://www.hardwareandtools.com/invt/u720526
