3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Three Axis CNC Machine (Cheaply and Easily)
The idea behind this Instructable was to fulfill my desire for a desktop sized CNC machine. While it would have been nice to purchase an off the shelf unit the issue of price as well as size proved prohibitive. With this in mind I endeavored to design and build a three axis CNC machine with the following factors in mind:
-Use Simple tools (needs only a drill press, band saw, and hand tools)
-Low Cost (this kind of got away from me however with everything bought off the shelf the cost for all parts is under $600 (significant savings could be made by skillfully sourcing some pieces))
-Small footprint (30" x 25" footprint)
-Usable working envelope (10" X-axis, 14" Y-Axis, 4" Z-Axis)
-Relativly fast cut rate (60" per minute)
-Small part count (fewer than 30 unique parts)
-Easy to source parts (all parts available from 4 sources (Home Depot + 3 online sources)
-Ability to cut ply-wood (Succesful)
Lets get started...
UPDATE: - Coming soon the ability to order pre-cut MDF pieces from oomlout
Step 1Others Who Have Finished
A salute to those who have laboured through to this point (and to demonstrate that it is reproducable) Here are some pictures of other peoples machines.
Photo 1 - Chris and his friend put together this unit; laser cutting the parts out of half inch acrylic. Not only does it look super it must weigh a ton. But kudos, anyone who's worked with acrylic knows laser cutting it is great but it is a very very unfriendly material to drill and there is a lot of side drilling in this design. Good job guys, check out more details (and photos including some testing with circuit boards) on Chris's blog rainbowlazer.com. I particularly like his work with making 3-d objects out of 2d cuts (here) .
Photo 2 - Sam McCaskill has finished his desktop CNC machine and it's looking really really nice. Super impressively he also resisted the urge to cheat and cut all his pieces by hand. I'm really impressed.
Photo 3 - Angry Monk's - With MDF pieces cut on a laser cutter and drive converted from toothed belts to threaded rod
Photo 4 - Bret Golab's - Bret has completed his and gone through the extra step of getting it setup to work with Linux CNC (a task I attempted and was foiled by complexity). If you're interested in his settings you can send him a message (Instructable ID: bretlyssii ) ). Great job Bret!
(If you have built one and would like it featured here, please send me a PM and we can arrange for the sending of photos)
702 comments
1-40 of 702next »
Jan 11, 2008. 11:01 AMAngry_Monk says:
I started to build this over the summer. i had the parts laser cut at my college from the DXF file. i just completed it a week ago after modifying it for better precision on the X and Y axes. i replaced the belt dives with threaded rod so now i can step forward 0.001" no problem, i think i can even do 0.0005" fine.
modifying the X and Y axes for threaded rod control isn't that bad, the only hard parts were making the new motor mounts and controlling both sides of the Y axis with one stepper. i ended up controlling both the Y axis threaded rods (one on each side) by mounting the timing belt pulleys on the ends of the threaded rod and running a timing belt around the rods on the back of the machine.
the reason for all this is because i want to do very small precise machining. i already have milled a couple propeller molds, to lay carbon fiber over, that are 1" in diameter and need 6000 lines of G-code to mill. i actually have another being milled right now. they came over very nicely.
i have a video of my machine in action but its hard to see any details of the prop because of its size and because my camera won't auto focus during a video. http://www.youtube.com/watch?v=_rdFn6b7b6o
Jan 13, 2008. 5:07 AMkardinal7 says:
Hello,
I'm building one right now. The purpose of the machine is to mill PCB's i need the machine accurate to 0,001 . Did you try the machine with the standard building? How accurate it worked? Can you put images of the changes you have done?
Jan 13, 2008. 8:51 AMAngry_Monk says:
yes, i tried the machine with the standard planes. the Z axis is fine at 0.001" res, probably more. the X and Y belt driven axes were only good for about 0.002" res. note my micro stepping was at 1/4. i didn't want to increase micro stepping because that is more of a software way of increasing resolution, i want to increase resolution the hardware way so i know i'm really getting what i want. when i switched to threaded rods i did get a slower traverse speed on those axes but increased accuracy. i also needed a larger stepper for my Y axis because it was driving two threaded rods as opposed to one. a final note is that i used (2) screw in T-nuts to attach each threaded rod to the machine (and ball bearing at the ends for support and to reduce friction). the purpose of two T-nuts is so that they can both be attached to the machine but tightened against each other a little to help reduce backlash. this creates more friction on those axes but it greatly reduces backlash to near nothing. for this mod i just got a 205oz-in stepper from HobbyCNC, and a 77" timing belt (same type as the kind used here) from mastercarr. everything else: timing pulleys, 1/4" bearings, 8mm bearings etc.. i reused. i used the 8mm bearings to fashion some extra pulleys on the back side of the machine for the 77" timing belt.
May 26, 2008. 7:29 AMepo says:
Hi! Thanks for showing the details on the modifications you made of Stuart's instructable. I can see in your other image posted under "others who have finished" that you are using a ridgid laminate trimmer which have a variable speed feature. Let me pick on your brain and experience if you don't mind :) - How fast do you run the router? - where do you get your router or end mill bit? - what is the maximum depth of cut per pass do you subject your cnc? - Stuart indicated a feed rate of 60 ipm, do you have the same or you have another preference? - Have you used your cnc to cut mdf? I know that's a LOT of questions but will appreciate your insights. Thanks. Edgar
May 26, 2008. 9:04 AMAngry_Monk says:
its really not a lot of questions. sometimes you just have to ask, and i can answer. i run the router at close to max speed, i dont know the RPMs. i figure this CNC isn't exactly the most rigid one out there and if you cut at a decent speed things will flex a little, and i needed it to be very precise. so the higher the RPMs the less stress on the bit and such. you can get the cutting bits from Master Carr (they basically have close to everything, so if you ever need anything check there). for depth of cut.. again, i needed precision, so if you can sacrifice this you could cut lower. but i usually didn't go more than 1/8" deep per pass, and that would be a heavy cut rough pass. i think it got it to run good at 30-40 ipm, 60 is a little fast for the small parts i was cutting. when cutting i would go down to 3ipm. i haven't actually used the machine to cut MDF but i think it would do fine cutting it. i don't know how fast you would be able to go but you could cut it. a few things worth noting about this: when you pick a motor for this CNC make sure it has collets for 1/4" and1/8" tools. its a pain if it doesn't... but if you run into that (like i did) you can actually get a collet adapter from Drill Bit City.com. one major thing i noticed about this CNC was that although the I-Beam for the X axis traverse was strong in the Z direction (could take some weight) the carriage could rotate about the I-Beam (rotate about the X axis). this would make the carriage flex in a hard cut. if i were to redo these plans i would definitely do something to fix this. maybe add another I-beam about 4-6" away from the existing one to get more rotary support. i have to admin that after i built this it couldn't cut as precisely as i needed it to so i ended up buying a desktop CNC mill from Taig. since i already had the steppers and controller board from this i could buy the CNC ready version. but i do not regret building this, i will still keep using it as a CNC Router. it was great to build, it taught me a lot about CNC in general being that this was my first experience with it. but for those who just want to cut about good parts CNC style, then this works fine, plus its cutting area is huge (and easily scaled up.).
May 26, 2008. 4:41 PMepo says:
Hi! Thanks for spending time to answer my query :) and your insights will prove to be very useful as I optimize the performance of my cnc. Fastest rpm assuming that you had what I have (i.e., ridgid laminate trimmer) should be 35000. Currently I'm running g ocde with feed rate of 12ipm and wow you did ramp it up almost 3x. That will save me time! But then the issue of precision is the downside. I did anticipate using 1/8 bits so got an adapter to fit into the 1/4 spec of the trimmer. I have no problem visualizing flexing problems you experienced. Like you, this is my first cnc encounter and the experience will probably serve me well in the future. Out of curiosity, where did you purchase your taig unit and for how much? Regards.
May 26, 2008. 7:48 PMAngry_Monk says:
i got the taig mill from http://cartertools.com/ , the guy that runs the site is really nice and helpful. i got the CNC ready version and that was about 1100$. i really like it, its very nice and precise.
just an FYI, i could run this CNC router at 30-40 ipm but that was only rapid traverse. when cutting i went much slower. and even on 30-40ipm you can miss steps, 12ipm is better, but i would only go up to 20.
May 26, 2008. 11:17 PMepo says:
thanks
Oct 4, 2008. 1:57 AMwizardrule says:
Got the dxf file around you can post?
Oct 4, 2008. 9:13 AMAngry_Monk says:
He has the DXF for the parts under step 4.
Nov 2, 2008. 3:11 AMDodgy says:
In addition to my previous question, re rod vs belt drive, how does the tightly strung inox (stainless steel) wire compare? If I can get inox rod at a reasonable price, would that be the best thing to use? If I chose rod. I would like the highest amount of resolution I can get. I know that the finer the pitch of the thread is, the more resolution it will have, but what about the width of the rod? I thought originally that a thicker (M12) rod will be better, then I realised it would be heavier and harder for the motor to turn, and perhaps, give no resolution advantage, and perhaps, thinner is better! What's the deal? Thanks.
Nov 2, 2008. 8:11 AMAngry_Monk says:
the pitch of the threaded rod is really what is important. you just end up creating a worm gear drive. for greater resolution use finer threads, it will amount to a higher gear reduction. its all about the gear ratio. the greater the number of turns the motor has to turn to get the machine to move a distance X the higher your resolution and also the greater torque the machine has (added bonus). you can get the same gear reduction using a belt system but you you will just need to gear the motor down before it drives the belt, which is a lot harder than just using threaded rod.
Nov 4, 2008. 11:41 AMTorito says:
Are the y axis rails round or square? I couldn't find that out...
Nov 5, 2008. 9:22 AMgalaxyman7 says:
They are round. The only parts that needs square tubing are the "bearing blocks". These are what will have bearings attached to them so that they can slide along the rails.
Nov 5, 2008. 2:13 PMTorito says:
Thanks GalaxMan7!! I understood the bearings system, kind of autocenter rail and hard to move perpendicular to the rail. Excellent drawing! :) Do you have/know/test the diameter of the rail? What is the material of the bearing blocks, aluminium or wood? Thanks for your time.
Nov 8, 2008. 9:57 PMgalaxyman7 says:
The diameter of the rod is .5" DIA (aluminum). The square tube is .75" square (also aluminum). The bearings are 8 mm ID and 22 mm OD. Also, I forgot to draw the nuts on the end of the bearings that keep them on. I hope that answers your questions ;)
Nov 10, 2008. 2:43 AMTorito says:
Excellent, more than I expected. Thanks.
Jan 16, 2009. 10:04 AMoutland86 says:
Jan 16, 2009. 10:00 AMoutland86says: HI all Just thought i would update the offer for kits with a photo of the parts you get remember its all the hardware only thing you have to supply is the stepper motors and the driver electronics and of course a computer...i can help with support for assembly and what software etc you will need to get up and running only 14 kits left and i am sorry but i will not be making anymore...$560 includes shipping to the lower 48 states. these are sold at cost as a courtesy to those who want to make this machine but do not have time or tools to make from scratch. call me 320 469 0347 in minnesota and i can setup a paypal invoice to you or arrange payment or you can just send the money to me by Paypal paul@thelostradio.com and i will ship it right out dont forget to look at my other post here for more details. as i said i am now offering some telephone and email support to help you get your machine up and running. see picture below
Feb 9, 2009. 4:01 AMmattmolitor says:
Pictures of my completed build. I didn't stray very far from the plans presented here. I used the bigger motors on hobbyCNC and made a wooden box for the electronics, but most of the rest is the same. I glued some of the parts (gantry beam for instance) where it seemed like it would add a lot of strength. Things I observed during my build + My mistake was to cut the parts for a tight fit, this was a mistake, a tight fit with mdf parts means broken parts. + A lot of the cross drilling can be accomplished as you place the parts together. This allows the other piece to be a guide for your drill. + The design doesn't mention limit switches. I could probably stand to add these as I have already crashed it a couple of times playing around. + Use a router for the slots, trying to cut those with a drill is tough. I purchased and used a trim router that I will use as my second generation cutting tool. + There are a couple of places cap screws work better than hex bolts because the design shows two hex bolts so close together they are difficult to tighten. On the Z axis I just used 1 bolt rather than 2. I glued this whole assembly together anyway, so 1 bolt is more than enough. + The author mentions cutting out the parts on a band saw. I did a lot of this on the band saw, but it is very handy to have a scroll saw for a lot of the interior cuts. + I am very tempted to convert this to lead screws for all axis (as many others have done). + Building the base plate for vacuum fixturing would be a nice addition with probably not much effort.
Apr 24, 2009. 1:49 PMschweinhund227 says:
I am almost Ready to Make CHIPS ! I converted all my Axis to Lead Screws... and replace the Tool holder with a dedicated Spindle ! I modified the Original design... a little to accommodate my Needs. Thanks again to have Fired UP my Mind ! This has been FUN ! Will post a little movie once I get Her Moving !!!
Apr 27, 2009. 4:22 AMbarvaKouzel says:
very cool! do you think, you could post some specs and illustrations for the Lead Screws conversion? thanks
Apr 28, 2009. 9:36 PMschweinhund227 says:
I rather not at this time.. barvaKouzel. Not that I don't want to ! but it's not tested ... So I don't want peoples to Hang me to dry !!! Not yet anyway !!! LOL I just got my Transformer today and should find out soon if this conversion works... I'll keep you updated !!!
Jun 21, 2009. 4:37 PMepo says:
Hi! I know its been a long way since January but have to ask anyway. Do you still have the kits available? Thanks.
Jun 22, 2009. 7:16 AMoutland86 says:
Yes we do have a couple kits left. My husband is in Canada on a fishing trip and will be back by the end of the week.. If you would like to purchase one the cost $560 including shipping to the lower 48 states. Please pay by PayPal using a credit card and we can ship next Monday. If you have any other questions I speak with him once a day and I can have him answer them then. Thanks for the inquiry. Julie Campbell
Jul 16, 2009. 8:53 AMhypercube33 says:
What if I live in or near minnesota?
Jul 16, 2009. 9:55 AMoutland86 says:
Hi, You can save on shipping if you pick it up. It would be $500 and If you would like to purchase the stepper motors from me that would be an extra $100 so $600 for the kit including stepper motors if you were to pick it up. Thanks
Jul 31, 2009. 3:46 PMkgdesigns says:
Hi, do you have anymore of these kits available?
Jul 31, 2009. 4:08 PMoutland86 says:
hello yes i do have a couple left we can also now supply stepper motors and MACH 3 software to drive the machine
Sep 3, 2009. 9:28 AMtekenika says:
ref:How to Make a Three Axis CNC... Hi I want to make this machine. I saw your post in youtube. I need some help. I have a question. What keeps the machine on the track? (Y axis) Only the belt? I, like you, prefer to use threaded rods. Do you have a drawing of the modification? Thanks and best regards from now Hector Ushuaia
Sep 3, 2009. 9:55 AMtekenika says:
Hi I, like you, prefer to use threaded rods. Do you have a drawing of the modification? Thanks and best regards from now Hector Ushuaia
Sep 3, 2009. 10:53 PMgalaxyman7 says:
Ok, here is a few pictures.
Sep 4, 2009. 2:29 PMtekenika says:
Thank you very much The diagrams are simple and clear. I follow with my questions. That keeps the machine on the rails? The threaded rods? Greetings
Sep 4, 2009. 11:44 PMgalaxyman7 says:
Yes, the threaded rod keeps it on the rails. I recommend using a thicker threaded rod so that there is very little movement. 3/4" would be perfect. You can get a PVC pipe coupler from 1/4" to 3/4", then you can drill holes into the side and put set screws through to hold the threaded rod to the motor shaft. Here is a website for an adapter.
http://www.gtghydroponics.com/store/0-0-715.htm
Sep 4, 2009. 11:45 PMgalaxyman7 says:
Sep 5, 2009. 9:14 AMtekenika says:
Hello Thank you very much for your attention. I agree. The threaded rod should be thicker. My problem is I'm planning a mini-mini version of this machine, using printer motors, it is possible that 3 / 4 is too much for these little motor. A possible solution could be carriers for bearings rotate 90 degrees. I should change the table a bit. Greetings Hector
Sep 5, 2009. 11:56 AMgalaxyman7 says:
Another way would be to add a seperate rod that the cart can slide on instead of relying on the strength of the threaded rod.
Sep 5, 2009. 6:40 PMtekenika says:
OK. It could be a solution. It will take a bronze bushing or bearing. Another possibility I've seen is to use an angle as rail. Deputy quick scheme. Greetings
Sep 8, 2009. 9:12 PMgalaxyman7 says:
The angle with the two bearings works only if you have a method to tighten them onto the rail. This means you either have two on either side of a track that can be tightened inward, or you have a track on both the right and the left, where the distance between the tracks can be extended. The best is a combination with both. Here is a pic
Sep 9, 2009. 2:41 PMtekenika says:
We agree. For simplicity, I only showed one side. So the vertical line is dotted. In a small machine, the table itself could be angled to accommodate the aluminum angles. best regards
1-40 of 702next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
408
Author:oomlout
