Step 11Software, Wiring and Configuring
All Steps Viewing
We have a set of pre cut wood parts avaialble for this Router with all the edge boring done and cut professionally on a KOMO CNC..absolutely precise parts.
from MDF. an inexpensive option to ensure you have an accurate machine when you are done...www.makecnc.com
some minor improvments and modifications have been made to the original design.
also for FREE....FREE....FREE
you can download free from our site an extensive and comprehensive set of plans for this machine that includes the DXF files of all parts drawn by a professional draughtman with dogbone fillets added to allow you to cut the parts uisng a CNC router..as well as a set of drawings ready to laser cut.
a parts list and indervidual part drawings including metal parts belts etc to make building this cool little machine a breeze..hindreds of hours of work went into these plans and cut files and they are your for free..no obligations.
www.makecnc.com
Do an ebay search for. "3 axis stepper kit nema 23"
An older Pentium 4 computer is ideal for controlling a CNC machine.
These can easily be found for less than 100 dollars.
The information shared here is a valuable resource for many people.
Suggestions that this information should be censored may be short sighted.
Either No or not enough electronic information.
As I am building my own cnc router I have had to study multiple approaches
to the controller end of my machine.
There is alot of information out there
it would be nice if someone could put that into plain english too, I have found that some people are making it look much harder than it all really is.
Maybe they like doing things the hard way... lol
I have tested my stepper motors and am ready for a power supply,
but it took me a long time to figure out what I need because of all
the different conflicting information everybody has different ideas !.
I really wasn't sure how much power I would need for a power supply
12v-24v-36v ?
Then I found what I needed at stepperworld.com
That was after buying a stepperworld FET-3 controller on ebay.
Taking a look at stepperworld.com made the whole picture so much clearer.
I found I could boost my motors (I am using 2nd hand nema 23 step 6 wire motors. ) with 50w resistors using a 12 volt power supply .
I copy and pasted them below from stepperworld.com .
Power Resistors (50 watt rating): $5 ea
Assorted values available...
0.3 ohm, 0.5 ohm, 1 ohm, 1.5 ohm, 2 ohm, 2.5 ohm, 3 ohm, 3.3 ohm, 4 ohm, 5 ohm, 10 ohm, 20 ohm
Heavy Duty Power Supply: $30
ATX type power supply has 3.3v, 5v and 12v with enough current to drive 3 motors in HI TORQUE mode simultaneously. AC power cord included. Power Supply is International (Input voltage range 100VAC to 240VAC) Power Supply is prepped to turn on without requiring any load or motherboard connection.
If you are looking and are overwhelmed by too many choices then I know how you feel.
6 wire motors are unipolar types so that limits the drivers you can use. Most folks try to use bipolar motors for increased performance. I've made some unipolar drivers based on Allegro chopping drivers though. They're OK I guess.
I have some electronics background. I suppose it helps me out a little with all of this. That motor driver in the pictures will wind a motor up to about 2,500 RPM. Which is so so stepper motor performance today.
http://www.instructables.com/id/Parallel-Port-Break-Out-Board-BOB/
http://www.instructables.com/id/300-Watt-Linear-Power-Supply/
http://www.instructables.com/id/TB6560-Microstepping-Bipolar-Chopper-Stepper-Motor/
All the electronics for a CNC machine. It is really pretty simple. All you need a power supply, An interface between your PC and your motor drivers, and the drivers themselves. As easy as 1, 2, 3 !
I'm afraid the power supply you've recommended is not a very good choice for high performance CNC. 12 volts just doesn't cut it. Dropping resistors went out in the 80s too. My driver I posted won't work with your unipolar motors.
I've made some drivers out of Allegro ICs that would though. They are similar to the drivers the author bought. I just used older SLA series ICs and made my own sequencers for mine.
http://img697.imageshack.us/img697/7711/pict0789w.jpg
I'm not going to say doing that is easy though.
www.KLM-ENTERPRISE.COM
hopefully this video will upload . it is not a fantastic video but ir shows
the wiring which no one would directly show me , even though I asked around on forums . I found my information through stepperworld.com
he answers his emails promptly and was extremly helpful.
I found that there are a lot of guys out there that take all the info they can find
and don't share it then other people that do share info and do go out of their way to help.
I spent a lot of time spooling through troves of information to build my own machine - is nearly complete and I did it very cost effectively. It can be done !
There are many people that don't want to wait and just want a plug in and go machine , others buy kits to assemble.
His videos show step by step how to assemble from crossing the t-s to dotting the i-s. add him to your sunbscriptions watch and learn. He has a lot of videos and a brand new book on amazon.com. I want one !
anyone want to buy me a present , please ...lol
http://youtu.be/xHtQeHqw-Tc
Hope my input helps someone out that may be going through similar problems.
It is a great learning experience for sure.
but for now , If anyone has a question I will try to point you in the right direction.
No I'm not a PRO, but I also have seen some teachers that shouldn't be PROS either. I like this site and intend on doing more and more here to show the talents that I have in different areas that may inspire others .
That is how I learned everything I know , watching people doing things and also reading about them.
Yawn but long lectures do put me to sleep though !
Advice : Students do try to stay awake in class because the moment you
doze off you'll miss the piece of information that is most important.
testing testing 2 2 3 4 4
Great project.
http://www.eminebea.com/content/html/en/hybrid_list/pdf/17PM-J.pdf
17PM-J503.
The guys who selling this told me that they come from an old copy machine and that he was about to use them to build a cnc.
If anyone can confirm this that would be really helpful.
Ciao
HS
Thanks
Thanks man!
