How to Make a Tornado Airsoft Grenade
14,047
9
41
Posted
Introduction: How to Make a Tornado Airsoft Grenade
This shows you how i made my tornado airsoft grenade from stuff i had lying around my house. it is reusable and easy to set up.
This is my first Ible and sorry my pictures are bad because i had to take them with me phone because my camera is broken
Step 1: Why?
I didn't want to spend $30 for a grenade that can usually only go once. And most of the grenades that people show you how to make usually have explosives  or they can go off in you hand or they only work once and you can't reset them during battle.
I also wanted one that people could make a couple of and are easy to make.
Step 2: Supplies
You need:
A wind back car with a big winder
a bic pen
tape
and something really small but heavy-i used a small bolt and a couple nuts
tape or epoxy or glue
airsoft bbs
Small piece of coat hanger
Tools:
Dremel with drill and cutting tool or something else that can cut throught plastic and a drill
Pliers
Step 3: Cutting Down
Ok now take apart your wind back car just leaving the plastic bottom with the rear end that has the wind backer on it and remember to keep the wheels on it
Then take your dremel with a cutting tool or what ever you are going to use and cut it down so there is as little as plastic around the winder but you have to leave the plastic on the bottom so when can mount the other things on
Step 4: Adding Weights
Ok now take your small nuts and screw them on to the small bolt.....use at least 2
Then take off one of the tires of your back axle on the wind back thing
Tape or glue the nuts and bolt onto the outside of the wheel
Then you can put the wheel back on
Step 5: Add the Barrels
ok now take your bic pens and you can use either one or two(i used one at first for when i taped it then i later epoxyed 2)
take out the ink cartridges out of the pens but keep the bottom caps on
now you can tape or epoxy the bic pens on
Make sure that open end of the bic pens or on the oppisite side of the weight wheel
Step 6: Add the Pull Pin
Cut a piece of coat hanger at least 3 inches long....longer if you want a bigger pin
bent the coat hanger at one end into a ring and leave at least one inch of the hanger straight
Now take your drill and drill a hole a little bit bigger then the coat hanger in the good wheel and into some of the plastic so when you put the coat hanger in it stops the wheel from turning
Step 7: How to Work It
So what you do is turn the winder for a bit or until it can't go any more and insert the pull pin all the way so the wheel doesn't turn
Now add bbs into the barrels and put the pen caps on them
To use take the caps off, pull the pin while holding the wheel so it doesn't spin and throw
Bbs should spin out of the barrels and go in about 15 foot spread of bbs
It really works if you have the right amount of weight so experiment on it
With 2 barrels it really shoot nicely and after you throw that what you do is charge in and start shooting
You really have to enforce it by adding tape or more epoxy
I have found that a decent throw will make it start spinning at about 15 feet after you throw it and that is where the bbs go so if you chuck it it might be a far grenade
This summer i will try to make an holder for it that will shoot over 100 bbs
Remember when you throw it to keep it level so the bbs don't fall out and i am going to try to make a stopper for that
Step 8: Future Designs
I might try to add a shell
I might add more bbs some how
Please leave comments and rate me
if you have any questions or need to clarify just send me a message
Thanks
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
41 Comments
What if you add a break away shell so it would go off on impact instead of throw and pray.
If you could add piece of string to the pin, you can delay the set off time by throwing it just past the length of the string...
Do you think that this would work with a camister and a bunch of holes in it and shorter tubes? Or woulld it be too weavy?
I like that you drew something up, I tried making something similar to this with copper tubing but i was curving the tubes down the canister and that didn't work out. The only problem with your design is that the tubes would be way to short, unless you mad it so once it hit the ground than the bbs flew everywhere which i have thought about before. It would be doable but would take some time. This winter i will try to come up with something like that and make it so you can either pull a pin, set up a trip wire to it, or make it so once it hits the ground than it fires.
Thanks for the idea and if you come up with something post it and post a link in the comments.
Zippy
Thanks, I will do a bit of experimenting on my own and maybe even make an instrucable about it if it works
That would be a great idea! and thanks again for the insite
Zippy
Do you have any ideas for a timer to keep t from going off in your face? I'm trying to build one but can't get it to not go off as soon as I throw it
Ya i will try to see if i can design a timer but i just normally use it for shorter throws or have haven attached it to the ground or a tree or by a bush and had some fishing line so when they hit the fishing line it went off.
Yea I would use it as that to but I'd like at least one second on a timer I'll think about to and tell you if I come up with any thing
ok that will be greatly appreciated!
