How to Make a Tugboat Toy Lamp
320
8
Published
Introduction: How to Make a Tugboat Toy Lamp
About: Wish Your Support.
We used a toddler's toy to make our lamp — one in which a child would insert a big Ping-Pong ball in the top and watch it roll down to the bottom. You can use most any type of plastic, metal or wood toy to make your own lamp.
Step 1: TOOLS & MATERIALS
TOOLS
  • drill and 3/8" drill bit
  • hole-saw drill bit
  • wire strippers
  • screwdriver
MATERIALS
  1. piece of wood for plug
  2. thread pipe and a piece of copper pipe that will slide over it
  3. lamp kit
  4. light bulb and lampshade
Step 2: Drill and Wire
To accommodate the wiring, drill two holes in the toy, one through the top (in our case, it is a smokestack) and one through the back. Feed the wire through the back and up through the top hole.
Step 3: ​Add Wood Plug and Pipe
If you have extra space to fill, like we do in our smokestack, make a wooden plug to sit inside the hole so it holds up the threaded pipe. Measure the diameter of the hole, then cut the wooden plug to size. Drill a hole in the center to hold the threaded pipe. Place the wooden plug with threaded pipe down over the wire and into the toy. Tap it into place.
Step 4: Cover the Threaded Pipe
Cover the threaded pipe with a copper pipe sleeve. Leave 1/2" on top to accommodate the connector and harp.
Step 5: Add Harp
Place the harp onto the pipe.
Step 6: Add the Socket
Wire the socket according to lamp kit package. Add an energy efficient low-wattage bulb and a lampshade.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    2 Comments
    Very nice! You really can make a lamp out of anything. Great instructable, thanks for sharing this! :)
