3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make a Vortex in a Bottle
  • last photo ←
We have had one of these around the house for years.  Our grandchildren, of all ages, love to watch the water swirl from the top bottle to the bottom bottle.  Our 2 ½ year old grandson would bring it to one of us, to have us swirl it, over and over again.  The first time I saw this principle used in life was when a Marine swirled a bottle of wine into a punch bowl, at a military wedding. It was way cool then, just as cool now.  Here is How to Make a Vortex in a Bottle.
Step 1
Supplies:
2 straight walled, 2 liter bottles with caps
5 minute epoxy (about $4.00 at craft stores)
Electrical tape
Small paper cup
Toothpick
Drill
½ drill bit
Candle
Matches
Pliers
Large nail
Sand paper, medium grit
Food coloring  (your choice of color)
50 comments
1-40 of 50next »
Dec 8, 2011. 9:19 PMvincent7520 says:
then are we north or south of the equator ?…
when I went to Brasil I was dumb enough not to have checked which side water turned when emptying from a tub in Europe, so when I got there I never really found out !!!…
childish, isn't it ?… (I'm 63 !!!!…)
Apr 19, 2012. 7:04 PMseraine says:
http://www.straightdope.com/columns/read/149/do-bathtubs-drain-counterclockwise-in-the-northern-hemisphere
Dec 8, 2011. 6:44 PMgaiatechnician says:
Does the vortex speed up as it runs or is it constant speed once it gets going? Maybe you could add some particles of something so we could tell this in the video?
Thanks
Brian
Dec 31, 2011. 9:57 AMwolfkeeper says:
The speed will increase until the liquid's viscosity limits the speed it can go, then it will go the same speed from then on.
You can go faster with a fluid of lower viscosity or if the bottle is larger diameter.
Dec 31, 2011. 9:55 AMwolfkeeper says:
You're right it would look faster, but it actually does go faster as it spirals in as well.
Angular momentum is speed times distance from the axis, and the distance has gone down, so conservation means it must have speeded up!
It's like tornadoes, that's how they get such incredibly high wind speeds.
Dec 4, 2011. 4:21 PMheathbar64 says:
so, how do you keep the water from all running out of the top bottle while you are swirling it up? and what effect does changing the hole size have?
Dec 19, 2011. 4:52 PMheathbar64 says:
ok, I made mine today. I'm thinking of trying smaller bottles for the next one. 2 litre's seem a bit cumbersome
Dec 17, 2011. 10:21 AMKozz says:
I was wondering whether I could weld the plastic somehow, rather than use epoxy, and found this great video. I hope it can help someone else, too. http://www.youtube.com/watch?v=hjMB-IsvURo&feature=player_embedded
Dec 10, 2011. 10:04 AMlouis.m says:
My mother taught me how to empty a bottle faster, by using a rotating wrist movement causing a vortex while holding the bottle upside down.
Dec 11, 2011. 9:18 AMRoyski says:
That's what some bottled beer drinkers do in competitions. It allows the displacement of air without the glugging effect. They swirl then quickly turn the bottle, open the epiglottis and pour straight down.
Dec 9, 2011. 5:00 AMAnnArborBuck says:
I've done these before, but one trick I figured out is that the bottle caps will fit nice and snug inside a piece of 1" (I think it was one inch off the top of my head, maybe 1 1/4") PVC Pipe. Just cut the pipe just long enough to hold to the two bottle caps, epoxy them into the pipe, and then when the epoxy dries drill the hole.
Using the PVC pipe makes the joint very strong so little kids can go nuts on it with no issues of breaking the joint, etc.
Dec 8, 2011. 3:25 PMdewexdewex says:
That's beautiful, and really well described in your write up. Thanks. I wonder if you could put a little pump to transfer the water from the bottom to the top and introduce it into the top bottle with a jet at an angle; a bit like a cyclone vac in reverse. That way it would be continuous.
Dec 8, 2011. 3:28 PMdewexdewex says:
Scratch that, this looks easier http://www.instructables.com/id/Water-vortex-tornado-Machine/ ;)
Dec 8, 2011. 11:43 AMRay-l-l says:
Love it. Simple, yet I could watch one for hours.
Dec 4, 2011. 7:40 PMramicaza says:
I'm sorry if this insults anybody but how did this get featured?
Dec 8, 2011. 7:01 AMLt.Greg says:
Well, I i kind of went - "Huh?" myself. Seems rather obvious for a feature piece. Then again is IS pretty cool, and anything that gets new people interested in science is definitely worthwhile!
Side note - I used to work in a HS science lab, and used distilled water to prep most of the chemistry. Flipping a 5 gallon water jug's spout into the 20 gallon large bottle - the water would take a while to flow from the 5 on top down into the 20 below. Glub --- glub --- g l u b -- g l u b .....
To speed up the transfer process, I used to give the full 5 gallon on top a quick swirl, which set up a vortex and allowed the entrained air in the lower jug to move up through the restriction while the water in the top jug flowed down and filled the main one. Every so often the kids would glance into my prep lab and see the tornado, and their eyes would go wide.
Dec 8, 2011. 7:29 AMrhdy says:
I first saw something like this (single bottle only) some 25+ years ago in high school from my physics teacher. He said this was the fastest way to empty a bottle because the air coming up through the middle enabled the liquid to empty most efficienty (as opposed to the "glurg glurg" interrupted pouring out). I'm guessing somewhere, sometime, someone has tested this.
Later I worked in a store that sold all sorts of items, and one was a Tornado Tube - you attached the two bottles to the threaded tube.
Dec 5, 2011. 7:54 AMdesmondtheredx says:
Australians, some africans, south americans and researches on Antartica are going to get diffrent results
Dec 8, 2011. 9:26 AMcesarakg says:
No. See http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html and http://en.wikipedia.org/wiki/List_of_common_misconceptions#Physics
Dec 5, 2011. 4:10 PMdesmondtheredx says:
oh yyeah 4got bout freezing in antartica
Dec 8, 2011. 10:16 AMleea9 says:
A store near me has sold a device to do just this for years. Nice science toy for the kids.
Dec 3, 2011. 7:57 PMPenolopy Bulnick says:
Nice! I always loved playing with this!
Dec 4, 2011. 9:21 AMrimar2000 says:
Very interesting.
Dec 4, 2011. 2:57 PMsunshiine says:
Thanks for sharing! These are so fun.
Sunshiine
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:craftknowitall(Nana's Blog)
In a valiant attempt to keep myself from dying of boredom, I create.
