3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Web Connected Robot (for about $500) (using an Arduino and Netbook)
This Instructable will show you how to build your own Web Connected Robot (using an Arduino micro-controller and Asus eee pc).
Why would you want a Web Connected Robot? To play with of course. Drive your robot from across the room or across the country, using nothing more than Skype and a web browser (nothing to install on the controlling computer). After that? Dig into the software & adapt it however you like, add a GPS so you can watch where you're driving on a map, add temperature sensors to map temperature gradients in your house, or sonar sensors to add controls on what you're web drivers can and cannot run into.
Features:
  • Inexpensive - (~$500 if you purchase all parts new and considerably cheaper if you dig around in your parts bin)
  • Once up and running controlling the robot requires only a web browser - (and Skype if you want to see where you're driving)
  • Open Source and Easily Adaptable - (uses an Arduino micro-controller, Processing for the web server & all software can be run on Linux (all the code is also heavily commented to make jumping in and changing things easy))
  • Modular Design (not a completely integrated system, if you want to use a different video conferencing service no worries, or if you have a Basic stamp rather than an Arduino just right a small piece of code and slot it in)
Here's a quick video of my Web Connected Robot being driven out of the kitchen.
Step 1Parts & Tools
Parts & Tools
Only a few parts are required:
Robot: Arduino Controlled Servo Robot - (SERB)
($175 @ oomlout.com ) or (make your own)
  • An open source robot which uses an Arduino micro-controller as it's brain.
(any dual servo robot platform with an arduino can be used (option 1) (please message me if you discover any other options)
Computer: Asus eee PC 4G
($280) (@Best Buy)
  • A small inexpensive laptop that is perfect for this purpose.
(any laptop (or desktop if you want to run with a chord) capable of running Processing sketches can be used)
Laptop Desk: Laser Cut Acrylic
($25 (@ oomlout) ) or (build your own step 3)
  • A few additional acrylic pieces which bolt onto a (SERB) to give it a desk for the laptop to sit on.
Nuts and Bols: (available at home depot)
  • 3mm x 10mm bolt (x4)
  • 3mm x 15mm bolt (x4)
  • 3mm nut (x8)
34 comments
Dec 2, 2011. 8:00 PMpkelley4 says:
The oomlout links for the chassis are not functioning. Are these still available?
Nov 15, 2011. 6:18 AMsynchr0nize says:
Is there a way to bind the keys you use to the keyboard instead of clicking left/right on the screen?
May 16, 2011. 6:59 AMAvadhut.Deshmukh says:
Good Job ! i like robot pc!
Feb 6, 2011. 1:11 PMPuze says:
Does anyone know how you can run this on linux?
Nov 9, 2010. 11:25 PMZsurzsaLaszlo says:
Hy, can someome tell me where can i find the Pattern for the wheels and the lower part of the robot?
Thanks,
Aug 11, 2010. 3:32 AMcrxksa says:
can you give me the code plz i am tring for 2 month still no progress crx.ksa@gmail.com
Sep 8, 2010. 3:36 PMD5quar3 says:
try using http://www.instructables.com/id/how-to-build-MACKRA-a-serb-variant/step7/the-software-arduino/
Aug 9, 2010. 11:53 PMcrxksa says:
can any one sent me The code for the arduino webserver crx.ksa@gmail.com
Sep 8, 2010. 9:45 AMkyle brinkerhoff says:
dude just use vspe , all your problems will be solved, for the video feed use webcam xp
Aug 21, 2010. 3:34 PMcrxksa says:
hi i build the robot it took 3days to do it , after i got the code from a member http://www.youtube.com/watch?v=OuyOQKXwtUA ok bye
Mar 30, 2010. 2:32 PMDingleNutZ says:
(removed by author or community request)
Aug 10, 2010. 1:55 AMcrxksa says:
Jul 26, 2010. 5:39 AMzmaster4 says:
really good tutorial :)
Jun 1, 2010. 11:59 AMameggs says:
 Can someone post the arduino code in an easier form so us NOOBS and use it. I really love this idea and Im already building the chassis now... just need the software.
Apr 4, 2010. 11:45 AMdaveo84 says:
 Using this code and the wiring diagram supplied, when I connect my arduino board via usb to any machine both servos start spinning...
What gives?
Feb 14, 2010. 10:05 AMrobotmaker says:
nice job tooo but missing 05-webb arduino.zip
Dec 27, 2009. 2:54 AMnanni78 says:
hello missing file 05-WEBB-Arduino Code.zip? good job
Nov 20, 2009. 9:17 AMdanielemur says:
Could you use Lego mindstorms?
Jul 8, 2009. 11:25 PMadrian.robb says:
I'm pretty sure Oomlout is an internet store only.
Either http://www.oomlout.com or http://www.oomlout.co.uk
Jul 3, 2009. 3:05 PMze.gmonteiro says:
Congratulations! I liked it very much... but wouldn't it be better if made from a Wishield instead of a netbook? (sorry about the English) http://asynclabs.com/home
May 1, 2009. 10:41 PMcats92 says:
Very nice and easy to use. Works well on the first try. Thanks
Mar 18, 2009. 1:54 AMmax_ruls says:
hay dood i love your web car well thats what i wood call it if i made it i wish that you coud tell me of an oomlout shop near brisbane if you can pleas can you email me at reif@tpg.com.au
Feb 23, 2009. 9:13 PMpsymansays says:
You can also use a VPN (LogMeIn Hamachi makes them easy) and write some simple TCP/IP client/server programs, to add proportional joystick support, and get better command-throughput than over HTTP.
I have something a little bit like this, that I built: http://www.youtube.com/watch?v=c4M8YzrSBqc
Feb 18, 2009. 8:04 PMraykholo says:
cant it just take commands from some website? maybe it would look at the blog section for text commands and u could password protect the site so it can do everything as u did here?
Feb 18, 2009. 8:06 PMraykholo says:
never mind - i just realized that thats what u did, i was thinking more about something without all the numbers, so u could just go onto www.(whatever).com , login, and take it from there...
Feb 10, 2009. 6:50 AMrics says:
Hi Stuart, Am I right that for a bigger laptop parts should be scaled properly? Bests, Richard
Feb 10, 2009. 6:30 AMrics says:
Hi Stuart, you mention the cdr and eps files in step 2 but there is no link to them as it was with SERB. Could you add them? (I already got the electronics working and I have a cardboard prototype robot but now I am thinking about waterjet cutting and these files may be helpful.) Bests, Richard
Jan 30, 2009. 9:47 AMvince086 says:
this is really cool !! 2 questions, Can this work with a windows 98 SE computer ? and Can it work using 9 pin Serial port instead of usb? never really got usb devices to work on old computer
Jan 19, 2009. 7:25 PMjoejoerowley says:
Great Instructable! 5 stars!
Jan 9, 2009. 4:14 AMluke says:
i have a eee, (check my instructables, would like to know what you think ) and last night i bought a arduino ..... that is creepy i think i may have to build this, but with tracks :D ( as i have them "in stock") very very nice job you have done by the way.
Nov 29, 2008. 10:04 AMmrbleh says:
I cant help but think of this: xkcd ROCKS!
Dec 16, 2008. 4:34 PMfishyfish777 says:
Yeah.
Dec 4, 2008. 11:02 AMevanwehrer says:
If you wanted to you could add a USB webcam so that you can have the laptop lid closed.
Nov 29, 2008. 10:07 AMmrbleh says:
Oh, and that's completely awesome, by the way.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
408
Author:oomlout
