Step 3Software - (Arduino)
First off the software running on the Arduino. It is a very simple program, what the Arduino does is monitor its serial port for data.
What it is looking for is a conversation 5 bytes long.
- Byte 1-3 (Check bytes "AAA")
- Byte 4 Command (Tells the arduino what to do) (Supported commands 'F' - Forward, 'B' - Backward, 'L' - Left, 'R' - Right, 'S' - Speed, 'X' - SetSpeedLeft, 'Y' - SetSpeedRight, 'C' - Stop)
- Byte 5 Parameter - For the move commands this is interpretted as a time interval (Parameter * 100 ms), and for the speed commands a percentage from 0-100
To Download:
- Download the attached zip file. (05-WEBB-Arduino Code.zip)
- Unzip to your Arduino Sketch directory. (default: My Documents\Arduino\)
- Open your arduino development enviroment and upload to your Arduino.
- Copy the code from below.
- Paste into the Arduino development environment.
- Upload to your Arduino.
/* * Arduino Controlled Web Connected Robot (WEBB) - Serial Host * For more details visit: http://www.oomlout.com/serb * * Behaviour: The Arduino listens to its Serial port for a command * in format 254, 88, 88, (COMMAND), (TIME) * Supported Commands - 'F' - 70 - Forward * 'B' - 66 - Backward * 'L' - 76 - Left * 'R' - 82 - Right * 'S' - 83 - Speed * 'X' - 88 - SetSpeedLeft * 'Y' - 89 - SetSpeedRight * 'C' - 67 - Stop * Supported Times - 0 - 255 (0 to 25.5 Seconds) value * 100 milliseconds *sp * Wiring: Right Servo Signal - pin 9 * Left Servo Signal - pin 10 * * License: This work is licenced under the Creative Commons * Attribution-Share Alike 3.0 Unported License. To * view a copy of this licence, visit * http://creativecommons.org/licenses/by-sa/3.0/ * or send a letter to Creative Commons, 171 Second * Street, Suite 300, San Francisco, California 94105, * USA. * */ //-------------------------------------------------------------------------//START OF ARDUINO SERIAL SERVER PREAMBLE//Defining constants corresponding to each command (also the ascii code number) #define FORWARD 70 //F#define BACKWARD 66 //B#define LEFT 76 //L#define RIGHT 82 //R#define SETSPEED 83 //S#define STOP 67 //C#define SETSPEEDLEFT 88 //X#define SETSPEEDRIGHT 89 //Y/*The three check bytes (used to keep the robot from responding to random serial *data) currently "AAA" */#define checkByte1 65 // "A"#define checkByte2 65 // "A"#define checkByte3 65 // "A" //--------------------------------------------------------------------------// START OF ARDUINO CONTROLLED SERVO ROBOT (SERB) PREAMBLE#include <Servo.h>#define LEFTSERVOPIN 10 //The pin the left servo is connected to#define RIGHTSERVOPIN 9 //The pin the right servo is connected toServo leftServo; Servo rightServo; int leftSpeed = 50; //holds the speed of the robots leftServo //a percentage between 0 and 100int rightSpeed = 100; //holds the speed of the robots rightServo //a percentage between 0 and 100// END OF ARDUINO CONTROLLED SERVO ROBOT (SERB) PREAMBLE//--------------------------------------------------------------------------//Gets everything up and runningvoid setup() { Serial.begin(9600); //Starts the serial port serbSetup(); //sets the state of all neccesary //pins and adds servos to your sketch}//The main program loopvoid loop() { serbPollSerialPort(); //continuously looks to the serial port //if there is data it processes it}//-----------------------------------------------------------------------//START OF ARDUINO SERIAL SERVER ROUTINES/* * Processes commands delivered to the arduino's serial port */void serbPollSerialPort(){ int dta; //variable to hold the serial byte if ( Serial.available() >= 5) { //if 5 bytes are in the buffer (length pf a full request) dta = Serial.read(); if ( dta = checkByte1){ //Checks for first check byte dta = Serial.read(); if ( dta = checkByte2){ //Checks for second check byte dta = Serial.read(); if ( dta = checkByte3){ //Checks for third check byte int command = Serial.read(); //Fourth byte is the command int param1 = Serial.read(); //Fifth byte is param1 interpretCommand(command, param1); //sends the parsed request to it's handler } } } }}/* * Takes the command and parameter and passes it to the robot */void interpretCommand(int command, int param1){if (command == FORWARD){goForward(); delay(param1 * 100); goStop();} //if forward else if(command == BACKWARD){goBackward(); delay(param1 * 100); goStop();} //if backwards else if(command == LEFT){goLeft(); delay(param1 * 100); goStop();} //if left else if(command == RIGHT){goRight(); delay(param1 * 100); goStop();} //if right else if(command == SETSPEED){setSpeed(param1);} //if setting speed else if(command == STOP){goStop();} //if stop else if(command == SETSPEEDLEFT){setSpeedLeft(param1);} //if setting left speed else if(command == SETSPEEDRIGHT){setSpeedRight(param1);} //if setting right speed else{ //if unrecognized command do a little shimmey goLeft(); delay(150); goRight(); delay(150); goStop(); }}//------------------------------------------------------------------------//START OF ARDUINO CONTROLLED SERVO ROBOT (SERB) ROUTINES/* * sets up your arduino to address your SERB using the included routines*/void serbSetup(){ setSpeed(leftSpeed); pinMode(LEFTSERVOPIN, OUTPUT); //sets the left servo signal pin //to output pinMode(RIGHTSERVOPIN, OUTPUT); //sets the right servo signal pin //to output leftServo.attach(LEFTSERVOPIN); //attaches left servo rightServo.attach(RIGHTSERVOPIN); //attaches right servo goStop();}/* * sets the speed of the robot between 0-(stopped) and 100-(full speed) * NOTE: speed will not change the current speed you must change speed * then call one of the go methods before changes occur.*/ void setSpeed(int newSpeed){ setSpeedLeft(newSpeed); //sets left speed setSpeedRight(newSpeed); //sets right speed}/* * Sets the speed of the left wheel */void setSpeedLeft(int newSpeed){ if(newSpeed >= 100) {newSpeed = 100;} //if speed is greater than 100 //make it 100 if(newSpeed <= 0) {newSpeed = 0;} //if speed is less than 0 make //it 0 leftSpeed = newSpeed * 0.9; //between 0 and 90}/* * Sets the speed of the right wheel */void setSpeedRight(int newSpeed){ if(newSpeed >= 100) {newSpeed = 100;} //if speed is greater than 100 //make it 100 if(newSpeed <= 0) {newSpeed = 0;} //if speed is less than 0 make //it 0 rightSpeed = newSpeed * 0.9; //scales the speed to be }/* * sends the robot forwards */void goForward(){ leftServo.write(90 + leftSpeed); rightServo.write(90 - rightSpeed);} /* * sends the robot backwards */void goBackward(){ leftServo.write(90 - leftSpeed); rightServo.write(90 + rightSpeed);} /* * sends the robot right */void goRight(){ leftServo.write(90 + leftSpeed); rightServo.write(90 + rightSpeed);}/* * sends the robot left */void goLeft(){ leftServo.write(90 - leftSpeed); rightServo.write(90 - rightSpeed);}/* * stops the robot */void goStop(){ leftServo.write(90); rightServo.write(90);}//END OF ARDUINO CONTROLLED SERVO ROBOT (SERB) ROUTINES//---------------------------------------------------------------------------| « Previous Step | Download PDFView All Steps | Next Step » |
8
comments
Add Comment
Add Comment
