Step 2The Snout
- Foam board
- Masking Tape
- Model Magic/Clay
- Ruler
- Pencil
- Cutting Tool
1: Take your piece of foam board and draw out your measurements with your pencil and ruler. (NOTE Pic 1) Take not of the different colored lines, they are important. If you wish to make the snout on your mask longer or shorter, feel free to play around with the measurements!
2: With your cutting tool, cut completely along the outside black line. Next, You need to do something called scoring. Take your blade and lightly cut the top surface of the foamboard, making sure not to completely cut through the entire board. (NOTE Pic #2) Then lightly fold the partially cut board at whatever angle looks appealing to you.
3: Take your masking tape, and place it upon the folded corners, so that it will retain the shape that you chose. (NOTE Pic #3)
4: Take a small piece of Model Magic, or clay, and form an incline at the tip of the snout. It doesn't have to be perfect. (NOTE Pic #4,5,6) Then wrap masking tape around all of the top. You use the end part of your pencil to push the clay in and give it nostils.
Add Comment
