What you'll need for this project:
A cardboard box (free) - My choice was a Taiwan Beer box, though you could use any brand, and if you can’t source a box with Chinese characters, then there’s nothing stopping you stencilling some on
A craft/utility knife (about $2US) - You’ll need a decent knife to make a clean cut around the characters
A lamp (about $8US) - All I could find was a work lamp and just removed the weather shield
Corrugated plastic sheets ($2US each) - I bought an orange and yellow sheet, both are about 4mm thick, though 2mm would also be fine
Adhesive - I used a glue gun, but super glue or any plastic adhesive would be fine, too
Time - About 3 to 5 hours, it really depends on how long you spent cutting out the characters
Taiwan Beer - or the beer of your choice, for drinking when you complete the lamp
Remove these ads by
Signing UpStep 1: Cut out the characters
Using your craft knife carefully start to cut out the Chinese characters from the cardboard box.
I found the best way to do this was to first score the first layer of the cardboard, the steadily go over the lines applying further pressure to cut through the corrugated layer. This is why you need a sharp knife with a blade locking function – otherwise you’ll end up with a rough cut or damaged cardboard from applying too much pressure.
One of the problems I had to overcome, was that as some parts of the characters were complete blocks, and if they were cut out completely would just leave a big hole, like a silhouette of the character. To get around this I opted to leave a small strip to the right of each such section. So long as you chose a system and stick to it, the characters should look uniform and the legibility shouldn’t be affected.
Cutting out the characters takes a long time, so you’d better get comfy – just don’t drink the beers at this stage, though, as you’ll need all of your fingers for the rest of the project.
Not Nice
Visit Our Store »
Go Pro Today »
