Step 2Cutting Pieces
Option 1 (Purchasing Pre-cut Parts)
- Purchase a pre-cut chassis from oomlout.com's store ( here ) ($60 including shipping to the USA and Canada)
- Download the laser cutter layout ( "03 SERB Ponoko Cutting Layout P2.eps" or "03-(SERB)-Ponoko Cutting Layout (P2).cdr" )
- Cut the files using Ponoko or on your own Laser Cutter (using 3mm, .118" acrylic (sometimes sold as .125")
- Download and print the PDF pattern (please choose the file corresponding to your paper size) 03-(SERB)-ScrollSaw Pattern (letter).pdf 03-(SERB)-ScrollSaw Pattern (A4).pdf(it is important to not scale the drawing while printing)
- Measure the ruler on the printout against a ruler you trust, if they do not match the pattern has been scaled and you need to look at your printer settings before reprinting. If they do match up, onwards.
- Glue the pattern to the acrylic sheet (3mm, .118" (sometimes sold as .125").
- Drill holes.
- Cutout pieces using a scroll saw
03 SERB Ponoko Cutting Layout P2.eps(1008x1041) 212 KB
03-(SERB)-ScrollSaw Pattern (A4).pdf(595x842) 35 KB
03-(SERB)-ScrollSaw Pattern (letter).pdf(612x792) 35 KB| « Previous Step | Download PDFView All Steps | Next Step » |
"You need to use a finer nib!
The cutting lines and/or vector engraving lines in your .eps file are thicker than we can handle. (We’ve highlighted the problem area(s) in your design here.) Please reduce all cutting and/or vector engraving lines to a thickness of 0.01mm then try again. "
Does anyone have the ability to fix this problem? Can you reupload the correct file to this Instructable please?
