How to Make an Automatic Night Light
Introduction: How to Make an Automatic Night Light
Automatic night light is a device with turns on light when there is darkness in the surrounding.
Its a portable version of automatic street lights. In this I used LDR (Light Dependent Resistor) which varies resistance with respect to light intensity.
For more projects subscribe my youtube channel [ Subscribe ]
Now I am going to instruct how to make an Automatic Night Light with less number of components.
Get Started..
Step 1: Components Required
LDR -1 ebay / Amazon
Resistor - 10k (x1)
Transistor - BC547 (x1) ebay / Amazon
9V Battery and Snap - 1
PCB -1 ebay / Amazon
LED -2
Step 2: Circuting
Place all components on PCB according to Circuit given above.
Note: adding a resistor of 330 ohms in series with led improves the lifetime of led.
Now solder all components.
Now solder 9V battery snap at respective terminals.
Place a piece of double sided tape on snap and stick the pcb to it.
Now connect battery to it.
For simulation fritzing file is attached
Step 3: Circuit Construction and Testing
For more projects subscribe my youtube channel [Click Here]
Feel free to comment.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    2 Questions
    How can i do if i want that to operate much Watt. I want too much Watt the output .
    You must use relay.
    importance of automatic night light?
    I see you didn't use any current limiting resistor in series with the LED(s) and the transistor. When the transistor is turned on, the current will flow through the LEDs without any current limiting. I suspect they won't last long. I would install at least a 330 ohm resister for one LED and at least a 160 ohm resister for two LEDs. JMHO
    Thank you for improving this Instructable.
