How to Make an Avant-Garde Robot Mask
Introduction: How to Make an Avant-Garde Robot Mask
Make a creepy robot plaster mask... without using Vaseline! Pose as a mannequin in shop windows, or hide in a closet and scare your friends.
Step 1: Materials
What you'll need for this project:
Plaster cloth roll
Aluminum Foil
Toilet Paper
Glue (Elmer's)
Duct Tape
Step 2: Making the Plaster Mask
Get your victim comfortable and pour water on a plate, or other container where it will be easy to dip the plaster strips. If you're nice, you'll make sure it's warm water.
Make sure you have a pile of plaster already cut into strips at the ready. Size doesn't matter than much, but strips that are around two inches wide and three inches long are manageable.
Begin by dipping small pieces of toilet paper into the water and laying them over your volunteer's face. Make sure you cover the entire face, making the toilet paper about four-five sheets thick all around. This way is less precise than slathering the face in Vaseline, but it's a lot cleaner and has less of a risk of the plaster sticking to the face.
Step 3: Using the Plaster
Once you finish the toilet paper protective layer, then you can start laying plaster strips on the face.
Dip the strips in your water and run your fingers together over the strip to make sure it's not too wet.
Apply the strips all over the face, using fingers to blend edges together.
You can apply as many layers as you want, but just make sure the mask is at least three layers thick, or it will likely break once dried.
Step 4: De-Masking
Pull the mask off.
I know, exciting.
Give it the night to dry.
Once it's dry, you can pull the toilet paper off from the back.
Step 5: Adding Aluminum Foil
Once the mask is dry, get out your glue, paint brush and aluminum foil.
Cover the mask in glue and use the brush to spread it out and then add strips of foil, smoothing them over the surface. Paint over the edges so they stay down. It'll dry clear.
Step 6: Adding Whatever You Want
If you want to keep the mask clean and simple, skip this step.
However, if you want to have fun decorating, go ahead.
I painted on some teeth to make it look creepier.
You can also find loose wire and glue that all over the mask to add to the robot-ness.
Step 7: Making Straps
To keep the mask on your face, you've got to make straps.
Cut two long strips of duct tape and fold them in so that you have a strip of double-sided tape.
Make sure to leave a piece of the sticky side remaining on the end of one strip.
Then staple the strips to the inside of the mask, one on each side.
This way, when you put the mask on, you can pull the strips back and they're stick.
It's pretty easy to take on and off.
Step 8: Scare People
Wear your mask. Enjoy it. Be a robot.
(making a robot warrior helmet out of cardboard is optional)
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Your vision is impaired. You cannot see. Your vision is impaired. You cannot see. (+5 nonexistant points if you get the reference) How are you supposed to get around? Echolocation is neat but it doesn't tell you when you're about to bust an ankle.
    Poke lil' holes out! Just make sure your out of the mask when you poke the holes.... I remember reading something like that from one of Kiteman's ibles.
    sounds like kiteman. I wonder if it would be possible to make holes or something but keep them invisible. Things without eyes are so much more fun.
    except when youre the one without them... i think, I wouldnt know too much on that.... Maybe some kind of chrome tinted plexiglass?
    there's a thought. A light dusting of silver spraypaint over plexiglass. It would be foggy but usable. Or to really simplify things, make the mask black and use inverted overtinted sunglass lenses.
    a 'grille' of pinholes in a single sheet of aluminum foil over an eye-sized hole. would look the same, but be transparent... mount the holie-foil on a circle of plastic from a clear plastic bottle, or some plexi...
    it's avant-garde, you don't have to see! but i guess you could poke little holes out.
