Introduction: How to Make an EMP Jammer
An electromagnetic pulse (EMP), also sometimes called a transient electromagnetic disturbance, is a short burst of electromagnetic energy. Such a pulse may occur in the form of a radiated electric or magnetic field or conducted electrical current depending on the source. EMP Jammer is a device capable of generating a transient electromagnetic disturbance that radiates outward from its epicenter, disrupting electronic devices.
For more projects subscribe my youtube channel [Click Here]
Now I am going to instruct how to make an EMP Jammer with less number of components.
Lets Get Started..
Step 1: Components Required
Picture of Components Required
Old bug zapper - 1 [Banggood]
Old Adapter Case - 1
Switch -1 [Banggood]
Hookup wire - 50cm.
Double Sided tape
Step 2: Circuiting
Picture of Circuiting
1. Take out the circuit out of the mosquito zapper.
2. Make a coil of 3-4 turns of hookup wire.
3. Solder one wire of coil to the anyone terminal of capacitor at output.
4. Glue another wire of coil near the another terminal of the capacitor at a distance of 2 mm or less than it.This is to create a spark gap.
5. Solder wire to circuit activating switch to extend the switch out of the case.
6. Place the circuit in the case carefully and turn on the circuit and close the case.
7. Apply glue on the case then fix the switch and solder activating switch extending wire to it.
8. Now apply a piece double sided tape to case and fix the battery.
Here the circuit construction completed.
For detailed construction check the video below.
Note : While using this device, keep your electronic devices away , because it may damage you device. I will not recommended to use it. I made this for educational purpose only.
Keep this device away from people who were installed with pacemaker,stunts.
Usage of this kind of devices is not allowed in some countries, make sure your countries policies before making this device.
Step 3: Construction and Testing
Feel free to comment.
morriganmcteag (author)2017-01-17
Your readers may be interested that in the US using this is a federal offense enforced by the fcc. The fine can be up to several tens of thousands of dollars. That assumes that homeland security doesn't decide that your planning terrorist. If your not in the USA check your government regulations (most have similar laws).
Thanks for your info, I updated in instructable.
thematthatter (author)JunezRiyaz2017-01-18
Monetary Penalties Can Exceed $100,000
per violation. Violations of the jamming prohibition can lead to
substantial monetary penalties (up to $122,500 for any single act),
seizure of the illegal jammer, and criminal sanctions including
imprisonment.
NilanjanS6 (author)2017-12-04
how to prevent this high voltage emp
a95123hsu (author)2017-04-25
can you give me the length, width and height of the adapter case. thank you!
ecrouch (author)2017-03-04
What factors are involved in the design of the coil? For example, why did you choose the number of turns that you did? Why that diameter?
Random Gadget Hacks (author)2017-03-01
who cares
vexvoltage (author)2017-02-10
There is almost no reason this should be made. Unless it's educational please do not make one of these.
henrique12345 (author)2017-01-20
I am just curious to know and was wanting to ask a question. Places like libraries, schools and cinemas have jammers that block signals from cell phones. If there is a security alarm in a library that is cellular based and a thief decides to break in, wont the jammer prevent the alarms signal from sending?
Oncer (author)2017-01-18
I've said it on other instructables for similar devices but this is just a weapon that could seriously injure or kill someone whom is reliant on an electronic regulatory device such as a pacemaker. It's as simple as that.
JunezRiyaz (author) Oncer2017-01-18
Yes, it leads to heart attack if they were installed with pacemaker,stunts.
ShradhhaW (author)2017-01-15
similar one build by Mr Kedar https://www.instructables.com/id/Destroy-Any-Device...
https://www.instructables.com/id/How-to-Make-EMP-Gu...
https://www.youtube.com/watch?v=l7UMJL3rB3Q
MartinJ11 (author)2017-01-15
How far away from an object does this work?
JunezRiyaz (author)MartinJ112017-01-15
My device works around 15cm distance effectively.
Working range depends on spark gap.
Creak (author)2017-01-14
What actually causes the disturbance? is it the coil or the spark gap?
JunezRiyaz (author)Creak2017-01-14
When spark is generated, a high energy magnetic field is ejected out from the coil. Here both spark gap and coil involves for generation of disturbances.
ThomasK19 (author)Creak2017-01-14
As soon as the spark travels through the air, a current will flow and the coil will create magnetic flux. The spark will extinguish immediately and that causes the flux in the coli to create a reaction which results in a momentary very high rise of voltage. This is a quite miraculous effect and to fully understand the details you probably need a basic study in physics.
The old spark plug coils in cars work similarly. The flux is started with a rotating finger running over a contact. While current flows, a flux is induced in the coil. When the current is interrupted, the flux will create a high voltage which now creates a spark in the plug. Unlike in this construction, the coil in a car is isolated and does not expose its magnetic flux but completely discharges the energy via the spark plug.
About This Instructable
25,582views
321favorites
License:
Bio: HI! I am Junez Riyaz, currently doing Bachelor of Technology in the field of Electronics and Communication Engineering. I am much interested in inventing something ... More »
More by JunezRiyaz:How to Make Simple Weather Station Using ArduinoHow to Make a Home Theater With Reclaimed SpeakersHow to connect I2C Lcd Display to Arduino Uno
Add instructable to:
