How to Make an Easy Starter Minecraft House With Easy to Find Materials in Game
112
Posted
Introduction: How to Make an Easy Starter Minecraft House With Easy to Find Materials in Game
THANK UUUUUUUU!
Step 1: Building the Base
first start the house by adding 6 blocks on the floor next to each other on a horizontal line. after that add 2 blocks to the right of it on one of the ends. then add 5 blocks parallel to the other 6 blocks on the end of the 2 blocks you placed. next add 4 blocks over next to the 2 blocks you placed. lastly put 5 blocks down under the the last block of the the 5 you last placed. if you want to house 2 people make it that when you put 4 blocks over next to the 2 blocks you turn it into 5 blocks
Step 2: The Walls
add walls as tall as you want though i would suggest you make them 3 locks higher.
Step 3: The Roof
create the roof b either making the wall higher or making a fancy pointed roof
Step 4: Light
add torches wherever there is space. i suggest you put it above your bed or beds. and above the door. in the mine or the other room put torches wherever.
Step 5: Furniture
put a bed in the middle of the big room or if you are housing 2 put 2 beds on the walls. make sure this goes against the back wall. ( the pillow side against the back wall) next put a crafting table in between the 2 beds or on 1 side of the 1 bed. then do the same with a furnace. lastly if you want to put chests against the side wall.also add doors
Step 6: Optional: Decorations
add your decorations of your choice i put roses in front of the house. if you want you can pictures in your house too
Step 7: Congradulations!!!!!!!!!
you just completed the easiest the most not useful house in minecraft unless you are just starting a new minecraft game!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    2 Comments
    yes it goes into a mining area.
    Looks good! Does that second door lead down into a mining area?
