Before we start making one, lets answer some basic questions like:
1. What is a Metronome and what does it do?
-A Metronome is a device that produces regular ticks (beats).
2. Who invented the Metronome?
-The mechanical Metronome was invented by Dietrich Nikolaus Winkel in Amsterdam in 1812. Johann Mälzel copied several of Winkel's construction ideas and received the patent for the portable Metronome in 1816.
3. What types of Metronomes are there?
a) Mechanical Metronomes
b) Electronic Metronomes ( the one we will be making)
c) Software Metronomes
4. Who uses Metronomes?
-Metronomes are used by musicians when practicing in order to maintain a constant tempo.
5. How is tempo measured?
-Tempo is measured in beats per minute (BPM). Metronomes can be set to variable tempi, usually ranging from 40 to 208 BPM.
6. Why would I want a Metronome?
- If you are a proud owner of an instrument, any kind ( guitar, piano, tuba, trumpet, violine...) you have to have a Metronome in the home. If you don't own any instruments you can use it to make your self fall asleep.
If you decided to build your own Metronome, then lets head to the next step and see what we need for this project!
Remove these ads by
Signing UpStep 1Components
1. 2 x LED ( I used blue ones, but you can use any colour you want)
2. 2 x 22uF 16V polarised capacitor
3. LM 555 Timer Chip
4. 8 pin chip holder (optional, but I suggest that you use it anyway)
5. 250K ohm Potentiometer
6. 3 x 1K ohm Resistors
7. Proto-board ( dots ) (The size of my board is 5cm X 9cm)
8. 9 V Battery clip
9. 8 Ohm Speaker ( Picture 1 and 2)
10. Some thin wire. I suggest you use solid wire for this project ( Picture 3)
11. 9V Battery
All of these components can be bought in you local Electronic shop. Here are some online stores where you can buy all of these components and much much more!
www.farnell.com/
ba.rs-online.com/web/
www.conrad-international.com/
www.allelectronics.com/index.php
Lets move on to the next step and see what Tools we need!
http://www.youtube.com/watch?v=sgB-Ih9jVt0
Later I will make a project box.
It's strange...that IC is very popular and you can find it almost everywhere :D
Vladjar
My son and I were thinking about making a metronome which would have his drum teacher's voice yelling "COUNT!" This looks like a good start. Would you (or someone) please suggest enhancements so we could add our own sounds?
Thanks!
Try playing with the potentiometer and get back to me! :)
Good luck!
Ah, I wish I had electronic classes! :)
I would need to look into it and tell you if any other extra components are needed!
Keep in touch!
Meni se jednom to desilo....metronom sam pravi puno puta.... i nikako nisam mogao da skontam u cemu je problem.......sve sam proverio...... na kraju sam odustao i napravio novi...
Proveri da ti kondenzatori stoje kako treba.... takodje proveri da nije 555 chip falican..... to je to sto mogu da ti dam od saveta....
