How to Make an Improbably Bright LED Task Lamp
 by spcutler
Featured
Step 3: Attach the mounting plate, heatsink, and LED plate together
The next step is to attach the main lamp components together.  You'll need the LED plate, your mounting block, the heatsink, some thermal paste, screws, and a drill/tap combo.
First step is to drill and tap the center bottom of your heatsink.    Most likely, this will be a "blind hole" meaning it doesn't go all the way through (since there is a fan in the way), so be extra careful with the tap.
Spread some thermal paste on the heatsink surface (the thinner the better, as long as you cover everything), place the block on top, and screw it into place tightly using the center hole.
Spread some more thermal paste on the block again and put the LED plate on top.  Screw it in tightly and you're done.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
