3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make an Irretrievable Easter Egg
Step 6Fix Any Mistakes
Fix Any Mistakes
After the concrete had setup, I decided to remove the plastic to let it dry faster. (I needed to use the egg the next day.) Sadly, a sizable portion of the concrete stuck to the inside of the egg. It probably latched onto the hot glue I'd used to fill the drain holes. So, I decided to put the two broken pieces of plastic back on and secure them with hot glue.
Try as I might, I couldn't get the broken pieces anywhere near as tight-fitting as they were moments earlier. Nevertheless, I forced them into place and slapped a stick-and-a-half of hot glue into the seams. This made the seams very visible. So, I decided to use that to my advantage and make the seams part of the decoration. I added more glue to look like piping. In the end, I reached a point where I was satisfied with how I'd hidden the breaks.
4 comments
Apr 9, 2009. 7:41 AMtgood says:
Great trick. Concrete dries by chemical reaction not evaporation. It should actually dry faster by leaving the plastic on.
Apr 9, 2009. 7:01 PMVermin says:
2 Ca3SiO5 + 7 H2O ---> 3 CaO.2SiO2.4H2O + 3 Ca(OH)2 is one of the (unbalanced) reactions.
Apr 9, 2011. 7:25 AMDELETED_madscientist167 says:
(removed by author or community request)
Apr 11, 2009. 10:22 AMchewingfoil says:
LOL You blinded him with science...it's exactly ON topic, because you showed him where the water went. Chemistry. Gotta love it.
Apr 9, 2009. 10:23 AMdutchypoodle says:
... the chemical process which cures cement causes it to heat up-- which vaporizes the water content, incidentally.
Apr 9, 2009. 12:30 PMOneEye says:
Most of the water becomes part of the cement, it isn't evaporated by the heat of reaction.
Apr 6, 2012. 3:29 PMsnowluck2345 says:
mrcumley.... you asked the question. interesting thing, in large concrete pouring they are water cooled to prevent them from breacking from the heat. look at the construction of the hoover dam.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:mrcrumley
(Is there a word that means more than "ultimate"? Oh well, I'l just make one up... "omnilent") Omnilently creative, MrCrumley fights a daily battle to save the world in his capacity as a multimedia ...
more »
