update - coming soon, lovely prepackaged kits from oomlout
Features:
--No difficult to source parts (no switches, relays, or IC's (everything but the motor is available at Home Depot).
--No soldering.
--Has a Mechano for grown-ups feel.
--Choice of options for cutting out pieces (scroll saw & drill, access to a laser cutter, purchasing online from Ponoko).
A quick video of the finished product walking through frame:
( A longer video of it navigating between obstacles can be found on step 7 )
Notes:
(If you would like any of the files in an editable format they can be found on a parallel Instructable here )
(Coming Soon, an Instructable on how to use a microcontroller (Arduino) to control the robot)
(I have used metric units and components in this Instructable. However those more familiar with imperial units do not despair, replacing the metric component with their nearest imperial counterpart should work (although I have yet to test this)) .
Remove these ads by
Signing UpStep 1Parts & Tools
(there is also a pdf version of the parts list attached to this step '21-(OAWR)-Parts List.pdf')
Parts List:
Nuts and Bolts: (~$10)
- 3mm x 15mm Bolt (x20)
- 3mm x 20mm Bolt (x2)
- 3mm x 30mm Bolt (x9)
- 3mm Washer (x48)
- 3mm Nut (x45)
- 4mm Nut (x26)
- 5mm Washer (12mm OD) (x2)
- Various Colours of Electrical Wire (~$5)
- Crimp Wire Terminals (red 5mm ring) (x18) (~$2)
- 2 AA Battery Box (x2) (~$2)
- Motor (Tamiya twin motor gearbox (#70097) (available from many online sources) ( on froogle ) ( manufacturers site ) ( sparkfun ) (~$10)
- Crank Set (Tamiya 3 mm Diameter Shaft Set) etamiya ) (<$10)
- Acrylic (150mm x 300mm x 3mm thick) (~$6)
- Whisker Wire (260mm x 1.6mm)(or two large paper clips) (~$1)
- Elastic Band
Required:
- Printer
- 5.5mm Wrench (x2)
- Screwdriver
- Pliers
- Crimp Terminal Crimpers
- Hot Glue Gun
Option 1 (Scrollsaw & Drill)
- Glue Stick
- Scroll saw
- Drill
- Drill Bits (3.2mm, 12.5mm, 16mm)
Option 2 (Ponoko)
- A Ponoko account
Option 3 (Access to a Laser Cutter)
- Access to a laser cutter
i make one in a bigger size ; it 'll be manage by an arduino to be atonomous
here is the link to the video
i 'll make an instructable when the project will be finish
thanks you
erreur404
just gona start assembling it..
was wondering ..
it doesnt use any sensors how does it work..?
thanks.
Goodness me that is a bit of a surprise.
A fall back is all the a parts nuts bolts wires, battery boxes etc. can be bought online at McMaster Carr http://mcmaster.com
thanks,
fidgety
