Introduction: How to Make an RC Plane Using Packing Material (Thermocol)
Picture of How to Make an RC Plane Using Packing Material (Thermocol)
Hello Everyone!
This is my first instructable and my first attempt of making a 3CH RC Plane and as a hobbyist I really enjoyed making, its a low wing type aerobatic flying model with ailerons and elevator (NO RUDDER), I started doing this project last year in my summer vacations, with my brother and it took us around 2 months to complete it.This aircraft is made totally using thermocol (Polystyrene) sheet and packing tapes used for reinforcement.
Using a very light material and shaping it to perfection was the most challenging part in this project, but somehow we managed to do it and fabrication was the part which took a lot of time here. The total size of the airplane is 42" x 36" and it weighs approximately 900 grams.
As this was my first try for making any RC plane, it did not turn out to be that perfect. It flies great though, had to do some adjustments on the transmitter and servos before getting it in the air. But do give it a try if you're really interested in making your own flying model like this for less money.
Your comments and suggestions would be highly appreciated and would also help me to make better instructables for all in future.
Good luck to all the RC pilots!!!
Step 1: Things You Need.
The materials required for this project are:
1. Polystyrene sheet (50" x 50") , 2 nos.
2. Masking tape, 2 rolls.
3. Hot Glue
Electronic Parts:
1. Brushless motor 1100KvA, 1 nos.
2. Servo, 2 nos.
3. 4CH Transmitter and Reciever (But only 3 channels are required, as there are only ailerons and elevator).
4. Propeller 3 x 10".
5. 11.1 V 3 cell battery(I have used a 2200 mAh battery here).
Tools Required:
Paper cutter, glue gun, hacksaw, pliers, drill machine, scissors.
Step 2: Getting Started
Picture of Getting Started
Download the given pdf plan, print it and paste on the thermocol sheet as shown in the above pictures.
Step 3: Cutting the Thermocol and Shaping It
Picture of Cutting the Thermocol and Shaping It
After you have successfully completed the step 2, cut out the thermocol carefully using a paper cutter.
Cut out the wings, fuselage and the middle part separately, carefully and sand it to get a perfect shape.
After cutting and sanding the edges, try and arrange in such a way that it should look as shown in the last two images shown above.
NOTE:
  • Make sure that the wings, ailerons, elevator and the fuselage are of the same length as in the printed plan
  • To get a fine cut in the theromcol sheet, you can heat the cutter on a candle and then use it through the sheet to avoid tearing of the sheet and get fine edges and a perfect slice.
Step 4: Shaping the Wing
Picture of Shaping the Wing
After you are done cutting the wing, cut out the aileron part separately.
Taper one side of the aileron, to give it enough room for movement as shown in the above picture.
Use masking tape to reinforce the thermocol. Apply the tape in layers, to give it a smooth finish.
Step 5: Servo Cut-outs
Picture of Servo Cut-outs
I have used only two servos in this plane, 1 for the ailerons and 1 for the elevator.
For Ailerons:
Make a groove of the same size as the servo through the fuselage so the servo arm can be extended and freely move on each side.
For Elevator:
Cut out another groove for another servo for elevator movement as seen in the picture above.
Make sure that the grooves and of the same size so the servo can be fixed in it properly and should not be loose from any side otherwise it will effect the servo operation.
Apply enough hot glue so that the servo fixes and gets sticked inside the groove properly.
Step 6: Reinforcement and Installation of Motor
Picture of Reinforcement and Installation of Motor
Cover the whole plane using masking tape, apply layer by layer to reinforce the thermocol and also to make it rigid. After that use any coloured tape to cover the whole aircraft and add some aesthetics to it. You can also use heat shrinkable sheet as well.
For Motor:
I have used an 1100 Kv Motor here, that comes with its own mount. Cut out a small piece of wood of size 2" x 2.5". Drill holes according to the motor mounts.
Place the wooden piece at the front of the fuselage by making a same sized groove in it, and apply hot glue to fix it properly.
Keep the motor there and screw it to the wooden piece properly, Use cable ties also if necessary, to add more support to it.
Similarly connect the ESC to the motor and extend the wire till the middle of the aircraft where you will place your receiver (RX).
Step 7: Wings Placement, Control Horns and Landing Gear
Picture of Wings Placement, Control Horns and Landing Gear
Mark the wing area on the body of the aircraft as mentioned in the plan.
Take two long BBQ sticks, use them as a supporting member for the wings, pinch the sticks through the body of the aircraft in such a way that it should be of the equal length on both the sides.
Mark two points on the wing as the same distance in the BBQ sticks.
Use a drill to make holes in the wing, and once done, slide the wing carefully on the BBQ sticks. This provides the wing firm hold with the body of the aircraft. Apply glue to fix is properly and rigidly.
Once the wings are attached, you can make the control horns, using either wooden sticks or buy them separately.
For the servo control again I have used BBQ sticks, attached with small piece of wire or paper clips, for which you can find DIY videos on youtube.
I also made a landing gear for it using a clothes hanger, which can be seen in the above pictures.
Step 8: Finding the C.G of the Aircraft and Battery Placement
Picture of Finding the C.G of the Aircraft and Battery Placement
To find out the CG of the aircraft you can either do it in the manual way which is that you tie a thread on the front and back end of the aircraft and try to balance it in such a way that the nose remains slightly upwards. Mark the center of the thread then and bring it straight down to the body of the aircraft, this will be your C.G.
You can also check for the point marked in the plan, and then trace it on the body of the aircraft.
This will also be the area where you will place your battery. Make a cut out of the size of the battery exactly over the area where you have marked your C.G. The battery should fit exactly into the cut-out so it doesnt fall out while flying and also to balance the weight equally in all parts of the aircraft.
Step 9: Final Touches and Adding All Components
Picture of Final Touches and Adding All Components
Last is to install all the components and then again checking the weight and C.G of the aircraft (preferably by the manual method). Try and keep all components in such a way that the whole weight of the plane balances equally on each side. Make sure to keep the nose slightly high as this will give you a better flight.
Once you're done with this, just program your transmitter and you are good to go with flying your scratch built RC plane.
rkrishnan7 (author)2016-09-19
You've done a great job for a first plane - if you can find poster board, the denser foam sandwiched in paper/cardboard in your area ("dollar tree" in the U.S.) you can build stronger model planes that can be more easily repaired.
Pink foam and BlueCore are also eminently suitable.
I think Thermocole is a brand name used for Polystryrene in India/Asia, just Polystyrene foam in the U.S. available in hardware stores for use as thermal insulation.
I wonder if you could strengthen and stiffen the leading edge by embedding bamboo stick ( 3 mm or 1/8" thick skewers, maybe ).
Lastly, with a little more powerful motor (more weight) , you could build from nearly indestructible fliers from corrugated plastic ( available from sign makers -- more politicians wanting your vote == more raw materials for flying models ;) )
YZKhan (author)rkrishnan72016-09-21
Thank you for your appreciation and comment, it really encourages me to do more work.
And yes for my next project I am planning to use the same sandwiched board commonly know as Foam Board here in Dubai.
Will surely put it up once its complete. :)
rkrishnan7 (author)YZKhan2016-09-21
There's also another great 'ible which lists many resources and materials for inexpensive R/C plane building. And he uses Styrofoam too! : https://www.instructables.com/id/Build-Classic-RC-Airplanes-With-New-Methods/
Waagzz made it! (author)2016-09-16
Coreflut is awsome for building light weight and cheap planes... I made a few and they fly great!
rkrishnan7 (author)Waagzz2016-09-19
I presume Coreflut is corrugated plastic (The kind that is used to make election time political signs) known as Coroplast in the U.S., Correx in the U.K..
abdelrazzac10 (author)2016-09-19
Nice job! Why don't you enter the drone contest?
https://www.instructables.com/contest/drones2016/
PhilippeG1 (author)2016-09-16
ends before your wings are not sanded, the edge must be rounded at the top of the wing down to create a vacuum above the plane making more effective pressure on the wing.
mbaldridge (author)PhilippeG12016-09-19
Actually, air deflection off the bottom of the wing is like 90% of a wing's lift anyway. The shape is mostly to make it aerodynamic. The vacuum theory is real, but it's only around 10% of a wing's lift on a good day. :)
YZKhan (author)PhilippeG12016-09-16
This was my first try, I realized after making this and when I was flying it. It does effect on its flight, but still was stable enough.
Will consider that for sure, when making my next model.
gm280 (author)YZKhan2016-09-18
Please understand I was certainly not criticizing your project, only offering an idea to make it easier to fly. Rounded front sections and profiled wings and surfaces will make it fly easier and faster. But I certainly am not stating you didn't have a great project. Ingenuity is everything and you proved that! Bravo sir bravo.
YZKhan (author)gm2802016-09-18
I definitely took it positive and I appreciate your advice. I am planning on making a new model now, as I have some free time, will definitely apply this technique and try to make a more profiled wing.
Thanks again for your valuable comments and suggestions :)
PierreV14 (author)2016-09-16
how much flight time do you get?
YZKhan (author)PierreV142016-09-18
That depends on the battery, ESC and motor used here. I have mentioned it in the project as well, I used a 2200 mAh, 3 cell battery, this gives me around 12-15 mins of flight time.
WannaDuino (author)2016-09-18
video of flight maybe?
YZKhan (author)WannaDuino2016-09-18
Unfortunately no. There was in my previous phone which works no more and I lost all my data with it.
But i'll surely make one the next time I fly it.
gm280 (author)2016-09-16
I am sure it flies, or you wouldn't have posted the project. But with flat straight wings, I am guessing you have to control the attack angle to achieve that flight. And that probably sucks a lot of capability out of it. If you would sand the wings into a streamlined design so that you actually create lift without the angle of attack, you would be amazed at the better flying and handling capabilities. Anything you can do to make it more aerodynamic would improve the capabilities without adding anything else to the design. But interesting concept all the same. JMHO
adenda2 (author)gm2802016-09-17
there are millions of planes built like this! lots of people take flat planes to the next level. you merely need enough thrust and control surface area. it flies better upside down this way too, instead of being pulled down by the airfoil.
YZKhan (author)gm2802016-09-16
This does give a little challenge while flying, but as it was my first project, the excitement took over the flaws :P
BTW Thank you for your precious advice, will surely try a more aerodynamic design next time.
Swansong (author)2016-09-16
This looks like so much fun! :)
YZKhan (author)Swansong2016-09-16
Thank you for your comment :)
YZKhan (author)2016-09-16
its my pleasure, and thank you for your comment.
You can use any type of motor it just depends on the weight of your aircraft.
About This Instructable
25,579views
181favorites
License:
More by YZKhan:How to make an RC Plane using packing material (Thermocol)
Add instructable to:
