Items needed:
- 2 *identical* picture frames. Get rid of the glass/acrylic sheet and only use the frame itself
- some sort of mesh, something like what is used on windows to keep the bugs out. You can get a fiberglass roll of this stuff for $7 at any hardware store (e.g. the Home Depot) and it works great
- duct tape
- nails and/or stapler
- hammer
- large tub that can fit both frames (one on top of the other) horizontally
- pestle and mortar or blender to mash up the paper to form a pulp
- old wool/acrylic/polyester blanket that can be cut up
- spray bottle
- sponge
- manual press or lots of books to press the paper down and squeeze water from the paper pulp
- paper (preferably used computer paper, as newspaper will give you bad quality recycled paper)
- something to cover your work space because this can get messy ;)
The picture below is just for the icon for this step. This picture is in context on step 5.
Step 1: Making the frame!
To do this, get one of the frames and put it on a table, with the smooth side facing up (the side without the grooves where you attach the back of the picture frame). Get your mesh/netting and put it on top of the picture frame. Cut up a piece that roughly matches the size of the picture frame.
Align the mesh so that it covers the whole picture frame, then nail it down. Make sure the net is *straight*, if it's wrinkly it won't work properly. I used a stapler because it's easier. If you use a normal stapler, slowly staple the mesh down to avoid bending the staples.
After the net is in place, hammer down the nails/staples to make sure they are "in" the wood, you don't want any spiky nails or staples sticking out.
(see pic)
Cut out any extra mesh you have (whatever is not on top of the frame) and duct tape the sides of the frames. Do not go over the "middle" of the frame, only tape the sides.
(see pics)
Your mold is now ready. The other frame remains unnetted, and is called the "deckle".
Now cut out the blanket in pieces that cover one of the frames entirely. After you've done that, it's time to shred paper.
(see pic)
Step 2: Making paper pulp!
(see pic)
When you don't see any clumps of paper or unshredded paper, you can stop blending it. You now have paper pulp.
Dump this paper pulp into the large tub and add water so that it covers the mold and deckle (one on top of the other) horizontally.
(see pic)
Step 3: Pulp to paper
(see pic)
After that, dip the frames in the tub. Note that the mold goes at the bottom, with the netted side facing up, and the deckle goes on top of it, smooth side facing down. If you don't use the two frames like this, you will probably not be able to remove the paper from the picture frame. It all makes sense when you do it yourself.
(see pic)
Rock the frames in the tub and make sure that the pulp is evenly distributed. When the mixture in the water is homogeneous, quickly lift up both frames. The pulp will get stuck to the mold. Let it drip for about 10 seconds and remove the deckle. You will notice that there is no pulp where the deckle was.
(see pic)
Step 4: Frame to blanket
(see pic)
Once the mold is flat on the blanket (pulp facing down), get a sponge and press it down on the net to suck up as much water as you can from the pulp.
(see pic)
After that, slowly lift up the mold. The paper pulp will remain attached to the blanket, and you can now reuse your frame.
(see pic)
Step 5: Making more paper!
(see pic)
If you keep making paper, you will eventually need to add pulp to the tub. Add pulp as you need it, and pile the newly made sheets on top of each other. Once you are done, put the books on top of the whole pile and let them sit for a while.
After a couple of hours, remove the books and lay the blankets with the paper pulp one by one to dry. It takes a while to dry, so be patient (about 1 day).
(see pic)
Step 6: Conclusion!
I use paper recycled this way with my photography to make nice greetings cards that I mail to friends etc. I also sell them through my website! :)
Be creative with your new hand crafted paper and tell me what you've done with it!
Visit Our Store »
Go Pro Today »
do not use shiny paper because it will have to sit for a cuple of weeks and byr then have gone bad news paper and old phone book are great to use have fun making what ever it is i had fun making a clock with my friends at school it's on my wall at home
If you mean in a blender for the blending process, 1:3 should work well. If in doubt, add more water. You can always squeeze it out later.
Nah, its another piece of felt or wool. The picture frame got removed and another piece of fabric replaced it.
I was able to do this using only ONE frame, but I got my hands dirty. As a final note, the final result of the paper isnt going to be perfected, but dont worry, because that is the charm of the recyced paper. :D
Or use a round baking pan to "cut" the shape into the still wet sheets (takes so little effort to tear the pulp).
As for fragrance oil, yup, it'll soak in. As for how fats it will leech back out into the air, I don't know. I'd be careful where you put it after putting oil on it though, gravity would cause the oil to want to soak through the bottom and ruin wood furniture and such...
note: cockroaches LLOVE starch, that's why i prefer glue.
The ned result is two interlocking frames.
I like the way you told people to use old fabric..cotton sheets and t-shirts work the best.
Why buy stuff ? I used to teach art and I taught this as a recycle project you don't need to buy anything. I used to go to flower shops and ask for the flowers that cannot be sold as well and put the petals in ....You can make molds and do paper casting too :) You can them put in objects of all sorts..Try not to buy stuff if you can folks we want to purchase less and be better to the planet...plus making stuff shows how super crafty we are :)
You have to make a strong binder and that can be out of natural things as well...
People made paper for thousands of years before we had Wall-mart ...
