Step 3Pulp to paper
(see pic)
After that, dip the frames in the tub. Note that the mold goes at the bottom, with the netted side facing up, and the deckle goes on top of it, smooth side facing down. If you don't use the two frames like this, you will probably not be able to remove the paper from the picture frame. It all makes sense when you do it yourself.
(see pic)
Rock the frames in the tub and make sure that the pulp is evenly distributed. When the mixture in the water is homogeneous, quickly lift up both frames. The pulp will get stuck to the mold. Let it drip for about 10 seconds and remove the deckle. You will notice that there is no pulp where the deckle was.
(see pic)
Add Comment
