3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make and Recycle Paper
Step 5Making more paper!
Making more paper!
Lay another blanket on top of the one you were just working on and press it down to squeeze as much water out of it as you can. I don't have a press, so I use a bunch of heavy books (that's where a lot of my university investments went to, to use books to press paper :( )
(see pic)
If you keep making paper, you will eventually need to add pulp to the tub. Add pulp as you need it, and pile the newly made sheets on top of each other. Once you are done, put the books on top of the whole pile and let them sit for a while.
After a couple of hours, remove the books and lay the blankets with the paper pulp one by one to dry. It takes a while to dry, so be patient (about 1 day).
(see pic)
4 comments
Feb 6, 2009. 12:33 PMahillenb says:
It looks like the picture frame is under the books, is that what i'm seeing?
Sep 22, 2011. 1:22 PMjaq_b_qwik says:
Ahillenb,
Nah, its another piece of felt or wool. The picture frame got removed and another piece of fabric replaced it.
Do you think cardboard would work?
Mar 20, 2009. 12:58 PMthepelton says:
Books aparrently were being used. I have had fairly good results driving out the water by putting a stiff piece of plywood, like maybe 3/4 inch (18mm) on the top of the stack, and standing on it, using my 190 pounds (86 KG) to drive out the water.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:Chopsteeq
