3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make some Charcoal
Step 12Updated Design of the Kooker
  • last photo ←
I decided that even though we were successful, that the process could use a major improvement.
The first burn lasted about 6 hours and consumed what seemed like a lot of wood.
I figured if I insulated the space around the Barrel that the heat would concentrate more on the container and the result would be faster conversion time and less wood burned.
I was right.
Here are pictures of my updated burner. The walls are one inch thick refractory cement. I used about 6.5 bags of refractory which weigh 55 lbs each. (So now the kiln / retort weighs at least 350 pounds!!)
You can see in the photos the steel structure and the refractory walls. I welded 1/4 inch round bar between the members as rebar and also tied chickenwire to those bars for supporting the refractory cement.
The front is bolted on so that it can be removed when the barrel wears out and needs to be replaced.
The floor is just the ground, and I laid down a piece of hardy-backer cement board to protect the concrete there. I added a hinged plate of steel there as a "fire box" door. It is about 1/4 inch thick and when closed there is about 4 inches open below it.
When burning it gets red hot as do the steel members of the structure!!
I also added a hole in the top as a place where the smoke can emit. I plan to add an insulated chimney to it there in the hopes that the fumes coming out can have a secondary burn to perhaps make less smoke. The chimney will need to be very well insulated for this to occur, so I plan to make it a double-wall arrangement probably 10-12 inches diameter outside with a 6-8 inch diameter inside pipe, and fill the gap between with kaowool or perlite.
The next step will be a short video of this one burning.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:juggler
