Step 13Video of new kooker burning
In the morning I discovered that 100% of the contents had converted to charcoal!!
The pile of wood in the picture below is what I took from to burn in the firebox. It is mostly still there!
So I don't know for sure, but I think I burned less wood in the firebox than was in the barrel, which is a huge improvement! The next burn will have more science. We will weigh the wood placed in the barrel, and note the type of wood. We will also weigh the wood burned in the firebox and then weigh the charcoal produced and time the process again. This process should give us a much better idea of the efficiency of the improved process.
Thanks for watching!
It is my guestimate that there are more modern people avoiding the revenuers via biodiesel than moonshine.
All you really need to do is route the exhaust gases from the fire, to the under side of your kettle.
The rest of your moonshine setup is as normal.
Just using one fire to do 2 different kinds of work.
If you are thinking about trying to make ethanol(aka NOT moonshine) from the wood byproduct... then the simple answer is no.
On top of that, we are not talking about drinking it at all, we are talking about using it for a fuel, which further reduces its similarities to moonshine.
Now, making moonshine is unconditionally illegal in all 50 states as far as I know. However, I believe it is 100% legal to distill alcohol IF and ONLY IF it is being used exclusively for fuel purposes.
It is legal to own a still if it is under 1 gallon, and you only use it for distilling water and extracting oils from plants.
Producing distilled alcoholic beverages requires some serious paperwork and fees (I looked into it, they are substantial). Distilling alcohol for fuel still requires permits and paperwork and fees, however, as long as you don't produce over a certain amount per year, and it never leaves your property, then you do not need to pay taxes on it, nor does it need to be denatured.
So, basically, its much easier to just do it illegally, they make doing the right thing unfeasible.
Allow me to make a correction: Making moonshine is unconditionally illegal in all 50 states of the United States as far as I know, I have no knowledge of other countries' laws however.
I did not mean to assume that everyone here is American, my mistake.
A moonshine-like beverage is not illegal if it is produced legally, with registered and licensed stills at a properly licensed distiller, however, since moonshine is by definition illegal (the definition of moonshine is an illegally produced and distilled alcoholic beverage), any moonshine-like beverage is not moonshine, although it may be chemically identical to moonshine, whether or not it IS moonshine is dependent on whether or not it was produced illegally.
So yeah making moonshine is unconditionally illegal, the same way that crime is unconditionally illegal.
This type of definition is not unprecedented in the world of alcoholic beverages, many types of spirits and wines are named after their content AS WELL as how and where they were produced, Champagne and Tequila and Bourbon being three good examples.
