3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make your Own Polymer Stamps
Make your own clear rubber stamps (polymer actually) to use on clay, polymer clay, fabric, paper, or anything else you can think of. This is an easy process that allows you to make stamps out of practically any black and white image you can come up with, and you can make them whatever size you like. They are also much less expensive than commercial rubber stamps. About 25 cents a square inch.
Step 1Gather all your equipment and supplies
The process of making a polymer stamp is a fairly straightforward, once you know the basics. Simply put, Photopolymer is a liquid polymer that is reactive to UV light and will harden when exposed. Knowing this, a negative can be made that allows the UV light to show through only where the stamp image is to be. The negative and polymer is exposed and the excess polymer washed away, leaving your custom rubber stamp.
There are two pieces of equipment that you will need to make to expose your rubber stamps, although both are very simple to make. The first is the UV exposure light. If you think you might be doing a lot of rubber stamp making I would invest in a fluorescent light fixture with UV (black light) bulbs to fit. You will need to attach two 6 “ x 6” wood boards to the side of the light to raise it 4” off of the table surface. Some light fixtures will need to have a cord attached, which can easily be done by cutting a 6’ extension cords female end off and direct wiring to the fixture. To make the light fixture easy to use a on/off switch may be wired to the light as well to make turning off the light between exposures easier. Another solution for those who don’t want to wire their light fixture is to simply purchase a clamp light and hang it 4 inches from the tabletop. They come with cords attached and a turn of button on the top of the fixture. You can purchase a flood style black light bulb to fit the fixture.
The second piece of equipment is the glass exposure plates. These are simply two matching sheets of 8 “ x 8” single pain clear glass , with the edges wrapped in electrical tape to keep your hands clear of sharp edges. Along two parallel edges of the taped plates lay magnetic tape on both sides. This will hold the plates together and keep them from shifting during the exposure process.
Materials
Light Fixture and UV Bulb
Developer Plates
Digital Timer (must measure seconds)
Photopolymer
Washout Solution
Substrate Film
Damming tape
Transparency Film
Two containers to hold liquid
Gentle scrub or tooth brush
Baby powder, Cornstarch, or talc
Optional
Clear acrylic or Plexiglass for mounting stamps
Pink erasor
26 comments
Mar 17, 2008. 8:02 PMGene Hacker says:
Where do you get photopolymer? And how much is it per unit? Is it expensive? I also believe, that you might be better off using an eeprom eraser than a black light for the photo exposure.
Apr 12, 2012. 8:42 AMgranthams says:
We provide the photopolymer on our website www.granthams.com . We have been using this process for over 30 years and happily answer any questions.
Mar 23, 2008. 11:54 PMdan says:
the easiest & cheapest UV setup i have found is "ladies nail polish dryer", these are widely available, compact and very inexpensive. they typically have 2 to 4 x 9-watt fluorescent UVA bulbs in them for under $50.
Apr 12, 2012. 8:44 AMgranthams says:
Walmart sells and single 17 watt blacklight flourescent bulb in fixture for about $10 which can be supported about 2" off your desktop.
Dec 22, 2008. 12:49 AMlatinatxunicorn says:
have you tried curing the photopolymer with one of these? if so, what was the average time for curing?
May 27, 2009. 8:35 AMmrpc77 says:
Wonderful step by step instructions. Where did you get all your materials? Thank you?
Apr 12, 2012. 8:41 AMgranthams says:
granthams.com is the source for both photopolymer stamp resin and pattern resin. Most of the photos are from our website
Nov 21, 2009. 2:52 PMroxxy says:
To save even more, you don't really need to use transparency film. Print on a regular sheet of paper, than lightly sponge with oil until everything but the inked portions remain opaque.
This technique is what is used in screen printing, which is also based on negative images used in conjunction with photosensitive materials.
Apr 12, 2012. 7:32 AMjrstudioboss says:
Roxy, are you saying that the oil on the unprinted areas of the paper will allow the UV to transfer through the paper and the printed areas will block it? What type of oil do you use?
Feb 22, 2011. 3:41 PMbuffysissy1 says:
Can you use this stuff or is it the wrong kind of polymer?
http://cgi.ebay.com/SUPER-EXPOSING-PRESENSITIZED-PHOTOPOLYMER-EMULSION-QT-/320661384387?pt=LH_DefaultDomain_0&hash=item4aa8e86cc3
Nov 5, 2010. 6:29 AMBarbCat says:
Oh, so cool. I wondered how to do this. One other great use for a blacklight (the bigger the better) is finding cat pee! You know it's there, maybe even think you found it. But you have no idea how vast the range is until seeing the spatter report all lit up.
Wait til dark, turn on that 60's party light and begin the hunt. Be ruthless! Look behind and under all furniture, inside closets and down heating vents, search way up high on doors and walls. On ceilings! Other things will glow (greasy smears from old Chinese-take out for instance) but not like this - greenish-yellow spatters and oh god, boggy pools you've been sloshing around in bare feet while bemoaning your nasty foot B.O. and thinking you'll never wear sandals again, or run barefoot in the grass or any other public place. Of course, if you're Peter Jackson, don't worry. You're excused.
But once tracked down, does it really matter since nothing seems to do a dang bit of good anyway? I spent gobs on Nature's Miracle, Pet Potty Pure, Enzyme-R-Us, etc. In desperation one day I grabbed the closest thing with a nozzle - and it worked! And it's not supposed to! According to Federal Law, they'll come and get you if it's not 'used as directed', which is to aim high and lightly spray to 'glycol-ize' cooking and ciggie-butt odors AND THAT'S IT. It's Ozium Air Sanitizer (Medco Industries). I aim low and drench and it's for cat-butt odor. So sue me.
So, once drenched (lightly) I cover the wet spot with a towel and a plastic garbage bag so nothing leaks. It's bad if the kitties lick it off their little feet (although there have been times...). After a few hours I walk on the towel - sometimes two or three - until it's blotted up. It's been about a month and so far so good.
It's an Honest-to-God Miracle, I tell ya. With 9 cats we were dying - literally - but no longer. We now invite guests over without fearing remorse and/or ugly gossip. It's always fun to see their amazed expressions (the ones who actually show up) once we convince them they can remove their surgical masks.
Being frugal, I was concerned I'd have little use for my Pee-Flee Light once the stink search became redundant (well, we can always throw 60's parties). But now, I get to use it to make stamps for my polymer clay obsession! Yay!
Love,
BarbaraCat
p.s. Gee, maybe the 'Animals' section should get a copy of this. Ya think? But shhh! Only us Indestructables - it's only fair. First, we buy lotsa stock and THEN tell all our other forums. The World will make a bum rush for Ozium Air Sanitizer and who'd blame them? We'll be rich!! Oh yeah, it works on those other odors too.
Apr 14, 2008. 7:19 AMvirgalcal says:
I love this! But, could someone please be more specific about the film supplies, substrate and where these can be purchased. Thanks!
Nov 30, 2008. 12:41 PMlexie02 says:
can u send me ordering info pleaselexie02@cableone.net
Apr 14, 2008. 11:36 AMvirgalcal says:
Thanks, I saw that. Can you give me the details of what's in the kit?
Mar 19, 2008. 5:33 AMcallmeshane says:
I have seen the 3D prototyping of this stuff done with a UV laser. Can one substitute a UV laser from a CD or DVD burner, on a CNC traverse to do precision "hardening" - accounting for diffusion, reactivity and speed of traverse on a CNC drive and fire cycle? It would be a more costly step, but one could jump directly from IMAGE to STAMP in one step.
Mar 20, 2008. 6:29 PMsumguysr says:
I am fairly sure that there are no UV lasers in CD or DVD burners. CD, DVD, and HD-DVD all use red lasers. Blue Ray obviously uses blue lasers, which may work. There are some holographic mediums that use UV lasers but it would probably be more economical to just buy a laser.
Apr 6, 2008. 7:53 PMTheBestJohn says:
CD Burners use UV lasers for burning and reading, DVD burners use red lasers for burning and UV for reading Blu-ray is well bluray
Mar 17, 2008. 4:27 PMKrieg1959 says:
how do i get the kit
Mar 17, 2008. 3:33 PMGorillazMiko says:
Nice job! I think the pictures should be better and bigger, but nice job, I want to make some Instructables Robot stamps. :P
Mar 16, 2008. 11:32 PMCameronSS says:
This looks pretty cool, but is there a chance for larger images with less JPEG compression? These are good images, but they're minuscule and compressed into oblivion.
Mar 17, 2008. 2:15 AMgmjhowe says:
I like, altho as cameron said, the pictures are low quality, i think that the instructions are perfect. and its not like u cant make out the pictures. Looks cool, just wish i had the equipment!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:CandylandCeramics
