How to Mask Off an Area for Aggressive Sandblasting
 by violet.sun
Featured
In this Instructable, I will show you how to mask off a particular area prior to sandblasting to protect it, in this case I will be masking off the emblem on a bike frame.  This type of masking is ideal for aggressive sandblasting at a close range for long periods of time.
Step 1: Cover Area with Vinyl
Cover the area you would like to protect from sandblasting with vinyl (with adhesive on one side).  Use enough vinyl that it covers more than the area you wish to mask.
blanchae says: Oct 4, 2012. 7:02 AM
I've thought of using the same masking material that they use when they sandblast gravestones for "etching" in the names.
rbafcj in reply to blanchaeOct 6, 2012. 8:55 PM
blanchae
What masking material would that be? and were can I find it? Please.
blanchae in reply to rbafcjOct 6, 2012. 10:42 PM
It is called sandmask - http://www.hartcoservice.com/sandmask
rbafcj in reply to blanchaeOct 8, 2012. 1:13 PM
Thank you I'll try it out on my next project
shakeval says: Oct 3, 2012. 6:22 PM
where is the result, we'd all like to see it......you know, proof it worked and such
M40 in reply to shakevalOct 4, 2012. 6:24 AM
The final picture shows the result... a well blasted surface and the masking material is still intact. Whether he shows the project itself painted/finished is a moot point as this is not about painting, bicycles, etc
The Instructable is indeed helpful to those of us who sandblast. I didn't know that vinyl/electrical tape was capable of absorbing/deflecting the blast media. I'll definitely be using that combo in the future.
Question: Would a couple layers of electrical tape work (without the vinyl layer)? Likewise, would a few layers of vinyl work?
zfoust in reply to M40Oct 7, 2012. 1:24 PM
I sandblast a lot for the natural gas industry and we use some pretty serious coal slag abrasive. When it comes to having to mask off fine threads, there's nothing better than electrical tape. The abrasive WILL push the glue into crevices and crannies, but this is easily removed with some solvent (brake cleaner works for EVERYTHING).
I.P.Freely in reply to M40Oct 4, 2012. 8:12 PM
I think I will try liquid electrical tape. Might work, might not.
mettaurlover in reply to I.P.FreelyOct 7, 2012. 1:51 AM
Won't work, that stuff has ZERO durability for any purpose but wiring insulation, and that's only because nothing is really exerting force on it.
violet.sun (author) in reply to M40Oct 4, 2012. 2:50 PM
I first tried several layers of vinyl but the edges peeled up and I also blasted through all the layers. Next I tried several layers of electrical tape which held up great but the adhesive embedded itself into the metal which was difficult to remove. The combo of vinyl under electrical tape has worked the best for me so far.
Wroger-Wroger in reply to violet.sunOct 4, 2012. 4:42 PM
Listen up - cause I am a genius.
1. Up to a point "rubber" types of media absorbs and deflects most of the abrasives energy - it flexes rather than cuts - but it will wear through eventually.
2. The direction of the gun has to be aiming the spray in a way that  is either near parrallel to the edge of the masking media or from the center of the masking media, to the metal around it.
- The maskign lifting is much like laying a sheet of paper on a flat surface and blowing at it - the paper will lift.
But if you blow at the paper, from the center to the edge, it stays stuck to the surface.
As much as the tapes have adhesive, and the bond may be quite good, with enough air pressure and hits by the abrasive, done close enough, for long enough, the abrasive blasting can lift the masking.
The same masking process is used in the sand blasting of windows - and if you do enough of the same pieces, you could make up a "permanent mask" out of silicon adhesive or rubber sheet - with it laid, clipped, / clamped / temporarily bonded into position.
The other thing is that you can paint on masking, using either latex rubber or slightly thinned neutral cure silicon - with turpentine, or even the contact adhesive.
As long as it's sticky and rubbery and is easy enough to get off either before or after painting without the rubber dissolving into the solvent.
Though that tends to be more of a time and paint depth issue.
Though with powder coating - it might just come away after baking.
Worth experimenting with I think.
SlickSqueegie in reply to M40Oct 4, 2012. 7:39 AM
The final pic does not show that it worked properly... we cannot see that the edges of the emblem were UN-touched... That is a lot of pressure blowing on those surfaces... I can see the edges peeling very easily while sandblasting... Just drill the rivets and pop the emblem off!
Quasinodoze says: Oct 6, 2012. 12:36 PM
When retexturing areas of injection mold after repairs, welding etc. I have used hotmelt glue with great success,good to cover edges of detail that must remain crisp and heavy enough to deflect aggressive grits and wears well, but above caveats about gun position apply and are critical to success. Build it up layer by layer as heavy as you need close to edges , then trim as needed to sharpen edges. just another way when other methodsnot as available or feasible.
systemBuilder says: Oct 4, 2012. 12:24 PM
I restore old Raleigh ten-speed Bicycles and have done 3x so far.
You can tap out the head badge rivet and buy new hollow pop rivets (3/32" stainless) at a few places on the internet.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120986658043
This Raleigh Sports has a 1977 or later head badge (as evidenced by the solid rivet, and I don't know a source for these), the 1976 and earler bikes had hollow rivets (like 3/32 above) that allow you to see into the head tube of the bike.
This badge has already lost all its paint. A good friend of mine who restores Cinellis recommends that you cut down a fine paint brush until there are just a few hairs available, and then repaint the badge under a microscope to get it looking like new again.
Good luck !!
CorruptedData says: Oct 4, 2012. 11:39 AM
Painstaking work, to be sure. But why not just drill out the head badge and reattach when you're done? Better yet, get a new (vintage) one off eBay? http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=raleigh+head+badge&_sacat=0&_from=R40
CorruptedData says: Oct 4, 2012. 11:32 AM
Off topic, but it looks like this frame may have sustained a front impact at some point. Maybe it's the perspective of the photo, but that downtube looks bent. But hell, these old Raleighs are bombproof. She'll hold together:)
WPee says: Oct 4, 2012. 11:08 AM
Sign Shops can order a thin rubber mask with an adhesive and a peal away backing that they can CUT the mask for you.
NOTE: It is used for precision masks in stainglass, & glue chip, & gold leaf, glass works...etc.
I did a quick digital snap shot and emailed it to the sign shop and they sent back a very good rubber mask. (we both fugged the images a bit to MAKE-IT-FIT.)
The imaged mask was to be wrapped around a tube much like this bike example.
Saved a lot of screwing around looking for the sandblast mat materials.
Jburchim says: Oct 4, 2012. 10:51 AM
For those interested in using resist for sandblasting, it is possible to use contact shelf liner for gravity feed blasting, there are also different media for blasting, ranging from walnut shells, corn cob media, to Silica Carbide. Walnut shells are an interesting biodegradable option as a blast media, that is not overly aggresive.
Your instructable was well done and informative.
drmax says: Oct 4, 2012. 10:23 AM
Hi, I miss the picture with the result, too. Also can someone explain me, why this article is featured? What are the requirements, that an article gets featured? Seriously.
cjohnson43 says: Oct 4, 2012. 9:57 AM
Gaffers Tape, similar to hockey tape, is what we use at work when we blast jet engine parts.
Sounds4cc says: Oct 4, 2012. 9:55 AM
I find just about any tape works; Even blue painters tape, packing tape. etc. Dont care for duct tape, the heat from the beads/sand impacting the tape makes it real gooey.
TinCan says: Oct 4, 2012. 9:46 AM
I've used multiple layers of self adhesive shelf paper, 3 layers seemed to work fine. It comes on a roll so you can cover large or small projects easily.
SlickSqueegie says: Oct 4, 2012. 7:36 AM
Nice instructable.. Normally I would just drill out those rivets and pop the emblem off and replace it after it is finished...
EET1982 says: Oct 2, 2012. 7:01 PM
Very cool. I never thought that was how you did it. Great instructable :).
audreyobscura says: Oct 2, 2012. 9:39 AM
Oh wow, that's how you do that. I am going to be repainting my vintage Peugeot soon, and I was curious how that was all going to work out. Thank's for the share.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
