How to Mirror IPhone to Android
Published
Introduction: How to Mirror IPhone to Android
Have you ever wondered if you can mirror iPhone to Android? If yes, then you’re probably stressed searching for the perfect app to use. Honestly speaking, only few applications allow this process. Most mirroring apps can only cast devices on computer, and not all works for iOS. So, if you are still finding what application can stream iPhone screen to Android, scroll down for more information.
Step 1: ApowerMirror
One mirroring application that you can use is ApowerMirror. This does not only cast Android and iOS devices on computer but also allows casting of iPhone to Android. The recent update of the app added this new functionality. Now, you will be able to view your iPhone using your Android. You can check the full instruction below:
Step 2: Get ApowerMirror.
Install the latest version of ApowerMirror on your Android and iPhone. You can download the app from the Google Play Store and App Store, respectively.
Step 3: Set Up Your Devices.
Connect your devices on the same WiFi network.
Step 4: Obtain QR Code.
On your Android, run ApowerMirror and click the "Cast" button (lower right corner of your screen). Hit the "Get QR Code" to see the code you need to scan.
Step 5: Scan QR Code.
On your iPhone, open the app and click on Scan. Scan the code on your Android using your iPhone’s camera.
Step 6: Mirror IPhone.
Swipe up your iPhone to open Control Center. From there, click on AirPlay Mirroring and select your Android device from the list.
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
