Introduction: How to Make Your Own 3D Printed Cookie Cutters
Picture of How to Make Your Own 3D Printed Cookie Cutters
Since I got my first 3D printer my mom all the time ask me to print something like decorations or fixes of something that broke in a house. One of her ideas last year was to print a cookie cutter for Christmas. So I design 3 cookie cutters and we made very original and cool cookie cutters. That was a year ago, I didn't post those cookie cutter anywhere online so here they are, old ones and new ones that I designed this year. I will also show you (or at least try to show you because I am not a good teacher) how you can design your very own cookie cutters based on the image. If you prefer watching a video instead of reading you can check it out above or if you are in app here is the link:
links to the 3D models can be found in the steps below. Keep in mind I wouldn't focus on how to make cookies, I am technician I have no idea how to cook :)
Don't forget to subscribe to my channel: https://goo.gl/x6Y32E
Are you read? let's put a santa clause hat on and start making it!
Step 1: What We Will Need?
Picture of What We Will Need?
We will need to know how to make cookies. Of course you can find a lot of great recipes right here on instructables. You can also buy some ready dough in the shop.
We will also need a 3D printer, if you don't have one don't worry, ask at school or at a library, maybe they have one. If not you can also buy one, here are 3 of in my opinion the best 3D printers, and they are really cheap so don't worry.
The best 3D printer that I have: https://goo.gl/XtDZft
Bigger 3D printer that I have: https://goo.gl/RyWHeL
Super cheap 3D printer: https://goo.gl/wCNKFJ
You will also need some filament here is a really good one for reasonable price. The gold one is awesome, thanks to glitter in it layers are less visible.
PLA: https://goo.gl/pJWAfL
Step 2: Download 3D Models/STL Files
Picture of Download 3D Models/STL Files
If you just want to download my cookie cutters and print them, here you can do it below you can find links to all of them on thingiverse. If you don't want to design your own cookie cutters you can end reading here :) If you want to know how to design your own cookie cutters keep reading there are just few more steps ;)
https://www.thingiverse.com/thing:2720869
https://www.thingiverse.com/thing:2720875
https://www.thingiverse.com/thing:2720879
https://www.thingiverse.com/thing:2720883
https://www.thingiverse.com/thing:2720893
https://www.thingiverse.com/thing:2720895
Step 3: What You Will Need to Design Your Own Cookie Cutters?
Picture of What You Will Need to Design Your Own Cookie Cutters?
Just one software - Fusion360 the best CAD for everything. If you are a student you can download it for free. You probably heard a lot about this software so I just want to say if you want to design things for 3D printing there is no better software than this one.
Step 4: Find an Image
Picture of Find an Image
Firstly you have to find an image that you want to make cookie cutter from. Just type in Google what you want and check clip art to find the easiest to make images. Also don't forget to choose the right license.
Step 5: Import Image to Fusion360
Picture of Import Image to Fusion360
When you have an image on your drive you can import it to Fusion360 by clicking import on the top and the cnava. Choose the image that you want to import and plane that you want to put it on.
Step 6: Trace the Line Around Your Object With Spline
Picture of Trace the Line Around Your Object With Spline
With spline tool we trace a line around our object. Spline tool is awesome and it easily adjust to the shape of an object like magic
Step 7: Create Outline of the Line That We Just Made
Picture of Create Outline of the Line That We Just Made
By clicking on the line that we just made and hitting O on the keyboard we can create an outline of the line. We have to set it to 0.8mm that's double of the 3D printer nozzle size (2 perimeters). If you have different nozzle size, you should change that to double of your nozzle size. You should do the same for all of the other line that have to cut a cookie.
Step 8: Extrude the Cutting Wall
Picture of Extrude the Cutting Wall
Select all the parts of the wall that will cut the cookie and extrude it by clicking E on the keyboard. 15 mm should be ok but you can put right there your own number.
Step 9: Extrude Embossing Parts
Picture of Extrude Embossing Parts
Select all of the other parts that should only embose things on the cookie, not cut. Best height for this parts is 14.2 mm so that's 0.8 mm less than the cutting wall. It will perfectly embose things on the cookie but wouldn't cut it.
Step 10: Add Some Supports for Our Bodies
Picture of Add Some Supports for Our Bodies
As you can see mouth, eyes and nose of snowman is separete from the main body, we should add few lines to connect it and make it possible to print that. Check out the difference on the images above.
Step 11: Join Everything
Picture of Join Everything
The last thing that we have to do is to select all of the bodies and click combine. Make sure that join is selected and hit ok. Now our bodies are connected into one body and we can easily print this cookie cutter.
Step 12: Conclusion
Picture of Conclusion
As you can see making your own cookie cutter is not hard at all, it's even very simple and effects are great! If don't want to design your own check out links to my cookie cutters. Don't forget to hit that like button and leave a comment :)
Follow me on social media:
Facebook: https://goo.gl/ZAQJXJ
Instagram: https://goo.gl/JLFLtf
Twitter: https://goo.gl/JLFLtf
Merry Christmas everybody!
KeithK25 (author)2017-12-19
I would add that if you are going to use an FDM printer, you should use a polypropylene filament, which is a food safe plastic. ABS and PLA are not.
About This Instructable
3,206views
27favorites
License:
Bio: Hi, my name is Nikodem Bartnik. I live in Poland, I'm 18 years old. I like to program and create robots, devices and things ... More »
More by Nikus:Simple Arduino Based POV DisplayHow to Make Your Own 3D Printed Cookie CuttersVery Simple Line Follower for Beginners
Add instructable to:
