Introduction: How to Mod an Xbox 360 Wireless Headset to Increase Battery Life
In This Instructable I Will Show You How To Double The life Of Your Wireless Headsets Battery From
6 Hours To 12 Hours With This Very Simple Mod.
Step 1: Materials
In Order To Do This You Need
1 Xbox 360 Wireless Headset
An Old Small MP3 Player (I Recommend A Audiophase KZIII MP3/VIDEO PLAYER)
A Soldering Iron With Rosin Core Solder
A Precision Screwdriver Set
And Some Safety Goggles
Step 2: The Parts
First Start By Opening The MP3 Player By Removing The Four Screws In The Back After That Remove The Two Screws Inside To Access The Battery Than Grab Your Soldering Iron And Remove The Battery Carefully Because Its Taped To The Main Board And Can Damage The Battery If Not Removed Properly
Step 3: Opening the Headset
Next You Need To Open The Headset Now To Do This You Must First Remove The Ear Loop Wear The Ear Loop Connects are The First Screws To Remove After That The Speaker Part Should Come Off Inside are Two more screws Then The Rest Of It Should Come Apart Then Remove The Battery From This the Same way You Removed The Battery From The MP3 Player
Step 4: The Assembly
Swap The Battery's Out And Solder The Connections Together Put The Screws Back In And Its Done You Have Just Doubled The Battery Life Of Your Wireless Headset
