Step 2Disassembling the yo-yo
You can use a safety pin to help pluck out the o-rings. Once they're removed, you won't really have a use for them anymore, but it doesn't hurt to keep them around if you change your mind.
If you have difficulty removing the bearing, you can use a pair of pliers to help get it out. Use a rubber band to protect the surface of the bearing. Pull the rubber band tight around the bearing then grip the pliers over the (now covered) bearing, then gently wiggle them back and forth to pull the bearing out.
Some players also remove the bearing shields, because this makes it easier to remove grime that accumulates as time goes on. If you choose to do this, take a safety pin and run it along the outside inner edge of the bearing until you get under the c-clip and pop it out. The shield should come off with little trouble. Repeat the process on the other side. This step isn't necessary, and also makes it easier for dirt to get in the bearing, but it does have its advantages if you decide to do it.
Add Comment
