Step 6Sand the yo-yo
Sanding your yo-yo won't make it any less responsive, but it will reduce the friction between your hand and the yo-yo's surface. The goal of sanding is to create concentric grooves from the yo-yos center, thus reducing the amount of surface area that your skin actually touches. It also removes the waxy coating that the yo-yo is shipped with.
I use a medium grit sandpaper. A fine grit doesn't make enough difference, and extra coarse is too much. I screw the two yo-yo halves tightly together without a bearing inside before sanding. Hold the sandpaper against the domed sides of your yo-yo and sand away. (You can push down with your middle finger to get into the crevices, using the gap of the yo-yo to keep your sandpaper centered.)
Remember, the goal is concentric circles, as if the yo-yo was spinning against the sandpaper. If you sand in all different directions, you will be creating more friction on the yo-yos surface.
After you finish sanding, unscrew the yo-yo and clean off the yo-yos surface. Try to avoid plastic waste that can get into the bearings.
Add Comment
