loading
Step 2: Step Two: Disassemble the Car
Using the rotary tool and drill attachment, drill out the metal rivets that hold the car's metal body to the plastic chassis. Drill deep enough to remove the lip of the metal rivet. You will need to exert some force, but be careful. If you do not have a rotary tool, you can try to use a hand drill and a sharp knife. But be warned, it is not easy. If this fails, cut or drill away at the soft plastic surrounding the rivet. Disassemble the car as much as possible. Separate the body, the interior, the windows, and the chassis. If it is possible to remove the external lights, do so.
I have this Mustang GT500 I have already made rear wing and mat black paint and I swapped it with wider rims with custom built wheel spacers, my next project is to make fender flares, please help me to build it, thanks
<p>Hey guys, long time collector of 1:18 scale cars. I have a project that I've wanted to do for a while. I have two maisto lamborghini murcielago's one of the first generation and a second of the lp640. I've had the first gen in an autoart model before and ultimately I want to do this project with autoart but I figured I would try and do it successfully with maisto because of the models cost. I want to place the first gen wheels and first gen tail lights on the lp640 car. That has always been my dislike of the lp640. Any recommendations?</p>
<p>How would I make a spoiler that looks like this?</p>
<p>how can i removethe paint without using blades</p>
if the car is white,can i paint it without removing the current paint?
I would still sand it. You need a rough surface for the paint to adhere.
what color do you recommend/your favorite colour for a honda nsx-r? this might sound unusual to you cuz planes is more your hobby than cars. and what other ways to remove the paint?
I would recommend a Gloss Red, Gunmetal Grey, or Black. The Carbon Fiber attachments won't stand out well if you opt for black. Another way you can remove the paint is to use paint stripper, thinner, or brake fluid. Be careful though, these chemicals are VERY corrosive.
can i add decals too if i want?
no. your not allowed
Yes, just print them out and glue them to the side.
still one of the best instructables on the site
I wouldn't go so far as to say one of the best... but still many thanks :).
if the window cannot be removed from the body,can i cover the windows with a tape or something that can be used for covering it?
You can try it, but I highly recommend that you do not. The tape job has to be perfect, or the paint will seep through and stain the edges. A good method is to cut out the windows and then re-glue them on (very carefully) afterwards with some clear glue. If the car and windows are all one piece metal, paint over the car AND the windows, and then paint the windows with blue or black permanent markers or paint.
what sharpies marker is that?sharpies or super sharpies?
Its just regular sharpies. You can use most permanent markers.
what is the difference of metal rivet to metal stud?
Both are two different words for essentially the same thing.
can i use illustration board covered with clear tape if both clear hard packaging plastic and cover card stock with clear tape are not available?
Yup. Anything that is thin and study, easy to cut, and can be covered with tape can be used.
its too difficult to modify a medium die-cast car?
Yes, it is very difficult. I've tried it with a BMW M3 and it didn't turn out too well. Start with smaller cars.
where can i get the Clear, hard plastic?
Electronics are usually packaged in them.
can anyone help me find a Ford Shelby GT500KR? Doesnt matter if its ebay or hobby lobby or anything in between
Never mind my first comment. Hotwheels now sells both the 1976 and 2008 GT500KR at Walmart.
Jada is the only brand that sells the GT500 KR. These are 1:18th scale and are incredibly detailed to begin with, so it will be extremely difficult to modify them with the methods shown in this instructable and make them look good.<br/>For the 2008 Ford Shelby GT500KR:<br/><a rel="nofollow" href="http://www.diecastfast.com/diecast/DCF/PROD/DC124-08MUS-S">http://www.diecastfast.com/diecast/DCF/PROD/DC124-08MUS-S</a><br/>For the 1976 Ford Shelby GT500KR:<br/><a rel="nofollow" href="http://www.idcow.com/jd2031.html">http://www.idcow.com/jd2031.html</a><br/>
where can i get the cover card stock with clear tape?
I meant to say that if you cannot get clear plastic, you can take a postcard and cover it with clear tape such as scotch tape. You can also use an ordinary piece of plastic as long as it is thin enough to cut.
how can i modify medium-sized die-cast cars?
I've tried it, but its pretty difficult. Your are going to need different materials to make it look good. You have any particular car in mind?
one of the keys to getting this right is practice -- get one or to crappy cars and you can butcher them as much as you will. plus it helps to know how aspects such as the paint you intend to use will turn out i practiced on a junky bmw and junky mustang, as well as testing various methods on other even cheaper cars A suggestion also for using sharpy for carbon: make sure you have got it DONE on the FIRST coat that way it will stay smooth and not start removing and not replacing what you already did
is there an other way to remove the rivets
I think I will do this to my 2010 Hotwheels Camaro as a tribute to Bumblebee from the movie Transformers. Yellow with black racing stripes!<br />
&nbsp;You could just go to Bunnings (if you live in Aussie) and buy acetone to remove all the paint without any plastic bits coz otherwise the plastic would melt.
&nbsp;Also, you can use DOT3 &amp; 4, polyethylene glycol based brake fluid to remove paint. They're plastic friendly in most cases as brake systems use plastic parts and a brake fluid that melts them would be a bad thing.<br />
Most brake fluids are plastic-friendly to begin with. However, it does not remove all of the paint. You need to scrape off the rest of the paint with a needle/knife/sandpaper.<br /> <div id="refHTML">&nbsp;</div>
do you still have to drill out the studs if the brand uses screws instead of rivets
No, just unscrew them. That is what you call a godsend, because drilling through rivets is a real pain (literally).<br /> <div id="refHTML">&nbsp;</div>
I'm working on 5 cars at the moment and about to start a sixth. and i find it useful to to scrape some paint on the car and then leave in white vinegar for about a 2 days and then removing the paint with a toothbrush, sandpaper and then a needle for the little nooks and crannies
Does anyone know where I could get a Nissan Skyline GT-R R34? I know that Hotwheels has a lot of R32's for sale at places like Target, but I am looking for an R34. If you don't know what it looks like, google it, or its the car Brian uses in the second and forth Fast And The Furious movies.
Tomy Takara makes many types of model Skyline R34's. In addition, they make a great model of the R35 GTR. I have one myself but I do not yet have the initiative to modify it. Beat me to the punch. -Pmet
sick!
wow this looks great. I'm working on the car and the box. My finished product will hopefully be "hoff" worthy
Make sure to put an image of the car! I'm excited to see it.
ha thats kool i used to play with tomy cars when i was little. ima dig up some and try this i have a nissan skyline it wood be awesome to try this.
try using oven cleaner, dot 3 brake fluid or "super clean" cleaner to remove paint. just spray it on and seal the car in a plastic bag or box, come back later with an old toothbrush and wipe off the paint. run the body through the dishwasher to clean it really good before priming and painting. you will end up with a "crisper" appearing body this way. I have been building models for ten years and welcome questions.
what type of dishwaser would you use to clean it. it seams like that is too much water power and tear some models up
true. I only use the dishwasher on metal bodies and use the "delicate" setting for fine china. you could also just scrub it with an old toothbrush and water. I'm just lazier than that.
About This Instructable
98,906views
25favorites
License:
More by pmet:Paper Space Shuttle Mini Staple Space Shuttle Mini Staple Cessna-172
Add instructable to:
