I apologize if I have offended people by modifying this camera I am not trying to "Destroy history" I'm just trying to have fun with it. Thanks.
Remove these ads by
Signing UpStep 1Tools and Materials, what you will need:
Materials:
1 piece of leather about a 1/16''
1 sheet of sticky foam paper
1 sheet of tin foil
2 sheets of plain paper
2 decorative knobs of your choice ( to advance and rewind film)
1 dowel: 3/8
1 piece of hard wood 2x2'', 8''
Saran wrap
polymer clay
black silk fabric
white glue (Elmer's or tacky) and old brush to apply it with
strong glue (Gorilla, Wood glue)
1 roll of film (for measuring purposes)
Tools:
sand paper
an awl (or something sharp and strong you can hit with a hammer[nail, screw])
a semi course round file
drill and pilot bits: 1/4, 3/8, 5/16,
1 small flat headed screwdriver
a fine ruler (goes up to 16th of an inch )
a squaring tool of some kind
hammer
a dremel and a bit to cut and sand metal
safety glasses
X-acto blade
1 sharp hand saw
air compressor or something to blow away metal shavings
Clamp
How do you count the frames?
ps sorry for the late response
Your measuring method is much the same i used for my (failed) lomolubitel 120-135 conversion.
I'm just wondering, why frame it as a normal ish 35? the lens should cover a good bit length wise on a 35mm at least 12cm on the role at a time, my lomo gave me about 6cm.
Then again i suffer form a major pano fetish ;)
-kyre
Makes me wonder what it takes to convert one of these to digital.
I certain used to use a polaroid back for my medium format cameras, so it's fun to see something in the opposite direction.
It will be interesting to see where the 35mm format goes in the 10-20 years, given that it's rising cost and shrinking availability means it's likely to be used mostly by artists, rather than commercial photogs or consumers...
