3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Mount Theatre Chairs for Free-Standing Installation
Typically for home theaters this type of chair is bolted directly to a concrete floor or to a larger wooden platform, but this instructable allows for greater flexibility for use in a multipurpose room.  The first time that I mounted these chairs I installed them all together on a single MDF deck cut from a 4'x8' sheet, but this time I chose to use stock, pre-cut birch veneer plywood so that the chairs could now be separated and moved around the room individually.  Like my previous install, I mounted the chairs at a slight angle to the deck base.
Step 1What you will need.
What you will need.
Materials:
     - 3/4" x 2' x 2' birch veneer plywood (1 per chair)
     - 1/4"x 1" bolts (4 per chair)
     - 1/4" x 1" washers (4 per chair)
     - 1/4" lock nuts (4 per chair)
     - smaller 1/4" washers (optionally used as spacers)
    (I started with bolts of various lengths because that's what I had at hand and used a
     hacksaw to cut the bolts flush once installed, but the 1" lengths worked without needing
     a trim.)
Tools:
     - electric drill
     - 1/4" wood drill bit
     - 1" wood drill bit and black electrical tape (see image note)
     -  7/16" socket and wrench
     - pencil
     - saw horses
4 comments
May 22, 2011. 9:42 PMrweidman says:
Just wanted to say thanks, I just mounted my theater chairs today. Nice instructions!
Dec 30, 2010. 7:15 AMSWV1787 says:
where did you find theater chairs?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mobilearchitect
