How to Obtain & Install CS:S(Counter Strike Source) Textures Onto Garry's Mod
394,113
11
37
Published
Introduction: How to Obtain & Install CS:S(Counter Strike Source) Textures Onto Garry's Mod
Using a simple server updater we can install Counter Strike Source Textures onto Garry's Mod.
Step 1: Step 1: Obtain Steam CMD
Download Here
Un-Zip the steamcmd_win32.zip file into a brand new folder
Step 2: Step 2: Run SteamCMD and Update
Double Click the SteamCMD.exe program that you unzipped into the new folder. It should start to update. New files will appear in your folder so don't freak out if that happens.
Step 3: Step 3: Download an Auto Loader
Download Here
Place in the folder that has everything else in it. Run it after everything has updated. IT WILL TAKE AWHILE.
Step 4: Step 4: Install the Textures
Make a new folder, Name it "CSS - Content." Go back to the folder that you placed the SteamCMD.exe program in. Open the "css" folder. Open the "cstrike" folder. Drag the "maps" folder and all of the "cstrike_pak###.vpk" files into your newly created "CSS - Content" folder. Then finally drag your "CSS - Content" folder into either
C:\Program Files (x86)\Steam\steamapps\common\garrysmod\garrysmod\addons\
OR
C:\Program Files (x86)\Steam\steamapps\\garrysmod\garrysmod\addons\
Step 5: Step 5: Download Vpk.exe and Unpack .vpk Files
Download it Here
Drag your .vpk files, one at a time, onto the vpk.exe program. They should unpack into a "cstrike_pak_dir" folder. Open that folder once your done unpacking all of your .vpk files, Only extract the folders within the "cstrike_pak_dir" folder to your "CSS - Content" folder. Delete the "cstrike_pak_dir" and your done. It should come out to look like the picture.
2 People Made This Project!
  • Stick It! Contest
    Stick It! Contest
  • Make it Move Contest
  • Clocks Contest
    Clocks Contest
Where can I find the auto loader? There is a 404 error when I get past the adfly
37 Comments
If you opened the application without moving it, how do you re-do it?
Or do you just keep going?
Also If you don't want the ads with the links above (they sometimes have viruses), you can get the GMOD Textures+video tutorial here,
site: gmod textures fix
An easy way to do it is but cs source copy the texture files from the game then import them into the gmod add ons folder
When I try to install the vpk.exe, it says, "The program can't start because vstdlib.dll is missing from your computer. Try reinstalling the program to fix this problem." Where can the vstdlib.dll be found?
It now works, but, it does nothing. I can't get my CSS - Content folder to look like that.
Basically, Step 5 doesn't make any sense to me
As Step 5 don't worry about downloading the vpk.exe. There is one already (and this one detects the tier0.dll file in the same folder) It is in
C:\Program Files\Steam\steamapps\common\GarrysMod\bin
Just use that one and it should work fine.
Thank you very much, you helped me too, just a correction if anyone is confused like i was, C:\Program Files (x86)\Steam\steamapps\common\GarrysMod\bin
You have no idea how much this helped me! Just a reminder por everyone, drag only the cstrike_pak_dir.vpk file directly to the vpk.exe in the path showed above. Do not copy the vpk.exe to another folder, as it will not work!
the folder that is suppose to show up,where is it located,i dragged the vpk files to the software,but it just opens commandprompt then closes.
It says that tier0.dll is missing even though it is in the same folder as vpk.
Can anyone help me?
Nevermind, I figured it out. Thanks a lot for this tutorial ! It really helped me a lot !
Anyway, i found another already-compiled addon of the content, in a old GM 9 crack.
Then i purchasd the original game, thanks you so much for the guide :)
I will not install or show dir. It says Installation failed
I placed the vpk.exe in steamcmd folder but it says tier0.dll can't be found, but it is in the same folder!i also tried to move vpk.exe to the css - content but the same, so can you help me?
You probably saw this comment 2 times, i just got login proplems so this is the 2nd time i wrie this.
Under
is also a vpk.exe just drag the files onto this file.
Look at TheJonoNewton's comment its helps a lot!
this really needs some editing
followed the instructions below but now i cant find the cstrike_pak_dir folder. i searched for it and it shows up as an add on installer
