Step 6: How to Obtain and Extract Americium
Okay,so now you know how to Obtain and Extract americium :-o
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Note:this is just a serious idea that just came into my mind.
First ,you should have the main element 196
80Hg which consists of 0.15% of the naturally occurring mercury. It is better because 196
80Hg is much easier to do it.Then use 241
95Am and an aluminium foil to make a neutron source.Aim neutrons to the target nucleus 196
80Hg and it will get converted into 197
80Hg which is a radioactive element and has a half life of 2 days,16 hours,8 minutes and 24 seconds.You will be surprised to hear this.The decay product of 197
80Hg is 197
79Au.this is an idea which i want to truly experiment with but I am not sure
that it will be correct because sometimes will 197
80Hg will break like fission of
uranium-235 and I am only 13 years old to do this.
http://www.scitoys.com/echem/elements/elements.html
this is plagriarism and not allowed on this site
Firstly, while alpha particles do not travel far in air, and many can be stopped by skin, they do penetrate to a degree. 22 micron thick paper with stop most of the alphas emitted from this particular radionuclide. The higher the energy thought, the further they go.
Secondly, and most importantly, the Am-241 decays with low energy gamma photons, but do not be deceived, what they lack in energy, they make up for in abundance leading to a very intense gamma radiation release per decay.
Hopefully, someone has the good sense to know that detection methods are varied, and each has an efficiency for a given type of radiative energy, be it corpuscular or photon. For Am-241, a Geiger counter for example is a TERRIBLE choice. The alpha needs to be measured independently of the gamma by alpha spectrometry. The gamma needs to be measured by either LSC (preferred), or gamma spectrometry (a suitable substitute).
1.0 microcurie may not seem like a big deal, but the radiation you aren't detecting is.
-Meitner
Further down in the posts here, you can make a random number generator. This is the same substance in all State Lottery machines in the United States for random number generation. So think of it this way, Every time you buy a quick pick lottery ticket, you are using Americium-241!
You can use it, in large quantities, to make a neutron source with a sheet of aluminium. The alpha radiation collides the the Al atoms and kicks off neutrons which you can collimate using a lead box with a hole drilled through it. However, you need 1000+ smoke detectors to get that much. And really there's no reason you should be making neutron sources in your home, but making a neutron diffractometer could be quite interesting though.
It's worth pointing out that you should wash your hands after handling the metal and make sure that you should keep it out of the way of children or anyone who might accidentally swallow it. I doubt the activity of the average smoke detector is particularly high, but ingesting an alpha source can be extremely dangerous if it gets lodged inside you.
Stay safe, kids and don't underestimate the danger of radioactive sources.
