I had an extra SATA drive around, so I thought why not replace it?
This version of the MyBook has no external screws and has to be opened similar to a bike tire.
Remove these ads by
Signing UpStep 1Supplies
The model is: WD3200D032.
Tools:
A flat blade screwdriver
A Phillips screwdriver
First of all, thanks for sharing your knowlage. Found your article via google.
But you did NOT use the correct methode to open the case.
Following upi your instructions, you WILL damage the case. Now the clips are broken, and the device can not close anymore.
Please alter your instruction, and instruct people to open the case by push down the 2 clips on top and bottom via the holes in the top and bottom in the front of the case.
This is meantioned before by "lemonshark10" and "nnnnnnnn".
@Admin: I would not pay for a site with incorrect instructions.
Thanks...
They had about 10min as well. They explained it as being a "warping" issue with some parts (maybe the actuator?) and the freezing allowed things to reform, but then warp again when it heats up after 10min.
http://www.seattlecomputerfix.com
This is a good way to damage the case. The generation of MyBook in the pictures is actually quite easy to open. Look at the tabs in step 4 -- using a flathead screwdriver you can depress the little nubbins on these tabs through the perforations in the metal casing. The two pieces of the shell will then slide apart without any prying. Hold onto the "book cover" with one hand and shimmy the perforated part back and forth to start the sliding.
I'm not sure about older MyBook drives but for the one pictured and later you should not have to pry at all!
