3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Open a Western Digital MyBook USB Drive.
After a few months of loud clicking coming out of my Western Digital MyBook it finally died.
I had an extra SATA drive around, so I thought why not replace it?
This version of the MyBook has no external screws and has to be opened similar to a bike tire.
Step 1Supplies
There are many models of MyBooks, this one has a set of blue LEDs that "spin" when the drive is active.
The model is: WD3200D032.
Tools:
A flat blade screwdriver
A Phillips screwdriver
25 comments
Dec 26, 2010. 12:25 AMjmeree says:
Mine has a little philips screw under on the the rubber foot pads. Once I took out that screw I could just push the plastic tabs on the side in and the unit slid out. Unfortunately, my hard drive is a IDE type connector, not SATA. Need to check how the $/gbyte are for those these days...
Sep 13, 2010. 8:25 AMYou_Broke_My_Book says:
Hi Joe,
First of all, thanks for sharing your knowlage. Found your article via google.
But you did NOT use the correct methode to open the case.
Following upi your instructions, you WILL damage the case. Now the clips are broken, and the device can not close anymore.
Please alter your instruction, and instruct people to open the case by push down the 2 clips on top and bottom via the holes in the top and bottom in the front of the case.
This is meantioned before by "lemonshark10" and "nnnnnnnn".
@Admin: I would not pay for a site with incorrect instructions.
Thanks...
Jun 30, 2010. 12:55 PMXenojimmy says:
I also have that screwdriver! i love it :P
Apr 24, 2009. 6:04 PMlump27 says:
Thanks man, I got this same type of case on my failed My Book, no screws anywhere on the outside. Still under warranty so I should get a replacement, i put it back together very carefully and looks same as it was before opening. I managed to rescue some irreplaceable photos by freezing the hard drive, then I connected it to my PC with a USB/IDE/Serial ATA adapter. Freezing it gave me like 10 minutes at a time to work with it each time I froze it so i had to freeze it about 5 times (24 hrs at a time or overnight) and rescue some data, happy to say I got all my irreplaceable stuff back... Thanks again ;)
May 13, 2010. 10:53 AMSyring says:
 Our IT guys did this same thing to recover a ppt psoter I had spent DAYS on.  Awesome little trick to have in the repertoire!  They were sure to put it in an anti static bag as well just to be safe.
They had about 10min as well.  They explained it as being a "warping" issue with some parts (maybe the actuator?) and the freezing allowed things to reform, but then warp again when it heats up after 10min.
Oct 27, 2009. 9:40 PMalexg69 says:
do you mean literally freeze it? or is it some thing else
Jan 22, 2010. 8:43 PMsleepydog says:
Yeah, he means he put it in his freezer to lower the temperature to make the hard drive work just long enough to get his data off. This is an old but useful trick for data recovery.
Sep 13, 2009. 3:32 PMrama2000 says:
Thanks a lot for your help
Aug 27, 2009. 6:07 PMspoonyfork says:
Awesome, thanks.
Aug 23, 2009. 4:37 PMlemonshark10 says:
There is no need to pop the edges the tabs merely slide through rails on the inside. one can just use a screw driver to push down the tab on the top and use a flathead to pull it back far enough that it doesn't go back into place and is under the grill crossbar things. then flip it over and repeat. more or less the entire cover can be removed just by doing step four and then sliding the two pieces of the case apart
May 13, 2009. 2:43 PMwww.seattlecomputerfix.com says:
Apr 5, 2009. 12:22 PMbrandonstiles says:
Hello. I have the Westen Digital My Book Essential Edition... 160 gigs. The light on my drive blinked quickly continuously. Basically meaning it wasnt getting the correct power it needed. So I took it to the shop where they took ait apart. The tech there informed me that my circuitboard has went out and that i would need to replace the circuitboard if I wanted the data off my drive. That is the only way to get power to my drive is to replace the board. WD sais they dont manafacture those drives anymore (remember Ive had this drive for four years) So basically I need a new circuitboard. Any suggestions?
Apr 2, 2009. 12:46 PMrenabee says:
This post saved my life! Literally....these instructions were so precise and easy to follow, and I got my data back. You rock!!!
Mar 28, 2009. 8:25 PMfarrers says:
Thanks mate! You're a genius! I knew there was a way to do this, but couldn't figure it out. Thanks for posting this! :)
Mar 10, 2009. 1:11 PMbwpatton1 says:
Ive got an old My book WD 160GB drive, ive had this for about a year and a half it works like a charm, its even quieter than my computer HD.
Feb 4, 2009. 8:37 AMEmTee48 says:
Good stuff this but on the WD3200I032 there is a hidden screw under one of the corner pads.
Dec 14, 2008. 10:39 AMnnnnnnnn says:
This is the only step you need to get the case off -- if you depress the tabs on the top and bottom as shown in the second photo here the case will slide apart.
Dec 14, 2008. 10:38 AMnnnnnnnn says:
STOP!
This is a good way to damage the case. The generation of MyBook in the pictures is actually quite easy to open. Look at the tabs in step 4 -- using a flathead screwdriver you can depress the little nubbins on these tabs through the perforations in the metal casing. The two pieces of the shell will then slide apart without any prying. Hold onto the "book cover" with one hand and shimmy the perforated part back and forth to start the sliding.
I'm not sure about older MyBook drives but for the one pictured and later you should not have to pry at all!
Aug 12, 2008. 6:01 AMbwcbwc says:
Nice to confirm that this is just a regular SATA drive inside. Plenty of new hacks (like routing the SATA connector outside the case) possible now.
May 29, 2008. 9:51 AMspankthejester says:
You saved me breaking this poor plastic beast!! Thanks!
May 14, 2008. 10:12 AMmedeaortica says:
ok.. assuming that in my dumminess my WD-HD fell yesterday from a table... (:(((((....) and now It looks like working, but it has even more strange noise then before (one of the noisest external drive I 've never had)... my problem is 1) how to ceck if everything is ok and I can still trust he device? 2) after the fall is a bit disassembled by itself, maybe falling on the edge made to slide a bit the parts and the rubber thing is not all in place and the shells like a bit opend... how to reassembly it in a propper way? It is better to open it all before?
Feb 4, 2008. 3:00 PMGorillazMiko says:
Cool! That's a huge USB drive.
Feb 21, 2008. 7:15 AMYerboogieman says:
its an external Hard Drive
Feb 6, 2008. 5:46 PMheretics_ghost says:
Also works on a WD3200I032! Only difference is that there is no metal trim.
Feb 4, 2008. 6:58 AMLinuxH4x0r says:
Awesome! My external drive died a few weeks ago and I'm going to do this as soon as I get a drive. Great job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
102
Author:joe
I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open and let me know how it goes. cheers, -Joe
