3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Open a Western Digital MyBook USB Drive.
Step 74 more screws
4 more screws
Remove the last 4 screws on the side of the actual hard drive.
Just replace with your sata drive and reverse the steps.
7 comments
Apr 24, 2009. 6:04 PMlump27 says:
Thanks man, I got this same type of case on my failed My Book, no screws anywhere on the outside. Still under warranty so I should get a replacement, i put it back together very carefully and looks same as it was before opening. I managed to rescue some irreplaceable photos by freezing the hard drive, then I connected it to my PC with a USB/IDE/Serial ATA adapter. Freezing it gave me like 10 minutes at a time to work with it each time I froze it so i had to freeze it about 5 times (24 hrs at a time or overnight) and rescue some data, happy to say I got all my irreplaceable stuff back... Thanks again ;)
May 13, 2010. 10:53 AMSyring says:
 Our IT guys did this same thing to recover a ppt psoter I had spent DAYS on.  Awesome little trick to have in the repertoire!  They were sure to put it in an anti static bag as well just to be safe.
They had about 10min as well.  They explained it as being a "warping" issue with some parts (maybe the actuator?) and the freezing allowed things to reform, but then warp again when it heats up after 10min.
Oct 27, 2009. 9:40 PMalexg69 says:
do you mean literally freeze it? or is it some thing else
Jan 22, 2010. 8:43 PMsleepydog says:
Yeah, he means he put it in his freezer to lower the temperature to make the hard drive work just long enough to get his data off. This is an old but useful trick for data recovery.
Sep 13, 2009. 3:32 PMrama2000 says:
Thanks a lot for your help
Aug 27, 2009. 6:07 PMspoonyfork says:
Awesome, thanks.
Mar 28, 2009. 8:25 PMfarrers says:
Thanks mate! You're a genius! I knew there was a way to do this, but couldn't figure it out. Thanks for posting this! :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
102
Author:joe
I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open and let me know how it goes. cheers, -Joe
